Question about Acer Computers & Internet
Acer travelmate 2350 wont boot or display
Hi, i have an acer travelmate 2350 all running good untill i switched on to get really high pitch noise would only stop when all power removed in battery. now i get no display all led light up correctly fan spins cd spins but then, nada, zip.zilch,nothing just sits there.
any help appreciated
  • techbug Feb 15, 2009
    hi, the noise was comming from the right side were both the hdd and ac power are housed certainly didnt sound like the hdd or fan.have tried changing ram cpu and running system with no hardware attached no joy. all leds light up as they should when cd rom is accessed or the hdd. also not getting beep when no ram in.
    is it possible to flash the bios with the system in this state
    thanks
  • Steve Si
    Steve Si May 11, 2010
    Where is the noise coming from (speakers, hard disk, fan?) - do you know?
    Does hard disk light flash when you switch it on - ie. is it booting but you just can't see any display?
    Try connecting a monitor.
    Do caps lock or num lock LEDs work if you press these keys?
    Maybe CPU is loose inside?
    If no text or display at all on power up, try removing hard disk and cd and battery and any thing else that you can just leave cpu and ram.
    If still no display, remove ram cards - it should beep to signal no ram - if so then CPU is probably OK - if no beep then CPU is probably not working.
    HTH
  • 77 Answers
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Posted on Feb 15, 2009
My acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
my acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
Jan 30, 2010 | Acer TravelMate 2300 Notebook
Cannot connect acer aspire one to projector. it's first detected when netbook is booting up but the connection dispappears (no input on projector) when the computer is fully on.
It should be a keyboard toggle to switch display to the projector, usually Fn + F5, sometimes you have to tap the F5 key a couple of times for the display to switch over.
Good luck
Jun 19, 2009 | Acer TravelMate 2300 Notebook
Acer Travelmate2350 display flikkering
Seem that your screen resolution changed. Turn off the notebook and again switch it back press F8 until it shows a list of option and then select SAFE MODE. Select it and enter into safe mode.
After welcome screen Right click on Desktop and select properties.
You will get Display Properties window.
Then select the Settings TAB in Display Properties. There select the screen resolution as low as you can 640by480 or 800by 600 then select apply and restart the Laptop.
The notebool should work normally as previously it work.
Hope this will be usefull
Thanks & regards
Nanda Kishore.
Jun 09, 2009 | Acer TravelMate 2303WLCi Notebook
Acer Travelmate 4060 boots to bios screen everytime
It seems that your RAMs are faulty..replace it..
Feb 27, 2009 | Acer TravelMate 2300 Notebook
Puppy 2.12 seamonkey on my acer travelmate 507T
Oh, I've had this issue before. You may have your resolution set too high or your installation program has selected the wrong driver for your display. Your going to have to go into display settings and change your display to the correct one.
Apr 25, 2008 | Acer TravelMate 507T Notebook
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Acer travelmate 2350 boot password
Do u know to use Soldering iron...if u know..remove the proccessor from socket then de solder the BIOS batterry and short that two terminals on mother board without connecting the power adapter and battery...do it and re solder the bios battery..this procedure will help u to recover from ur problem..if u dont know then do it with any technician.
Dec 09, 2007 | Acer TravelMate 2300 Notebook
Acer Travelmate 2350
if your cdrom stops installing the operating system, then either the processor is damaged or the hard drive is faulty, as initially the installation files have to be installed to run the main O.S installation
Sep 21, 2007 | Acer TravelMate 2300 Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
899 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
