Hi,i have a epsom cx6600 i have had it for 2 years. changed my ink yesterday all was fine,then i thought i would clean my heads.i got an error message,Parts inside your printer are at the end of their service life.but it was printing fine before is there anything i can do to disable this warning,i have tried pressing all the buttons but nothing will work.cath I have just bought a used Epson Stylus Photo R300. The seller told me it had not been used for a couple of months so I changed the carts, it printed reasonable after a number of clean cycles, but then it stopped printing and the 'parts inside your printer have reached the end of their service life etc.' message came up and it won't print at all now. Can someone help, please?
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
http://www.octoink.co.uk/store/pages/Epson-CX6600.html
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
