Question about Garmin Nuvi 760 Handheld GPS Receiver
I can not pair my NUVI 760 to my BLACKBERRY phone.
HELP !!!!
Thanks
N. Pereira - Lopes
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Have you tried running Garmin's webupdater to obtain the latest bluetooth firmware? Garmin updates the bluetooth firmware on occasion to make it compatible with newer phones coming out on the market.
    Also, do you have the bluetooth enabled? You can find the status in the settings menu. If it is not enabled, bluetooth will nort work.
    - Jim
Works fine with my bb Curve.... as suggested get the webupdater and update ! :)
Posted on Feb 20, 2009
My blackberry is asking for a code for my 760
The passkey for your headset is hardcoded to '0000' (four zeros).
If it fails to pair with your phone, turn it off. Then, press the PWR button for some 4 seconds, until its indicator light is steadily lit. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a little while, the HBM-760 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode.
Anyway, if its user guide happens to be missing, you can download it from this location.
Hope you are able to sort your problems out soon.
Regards, Carlos
Jan 02, 2011 | LG HBM-760 Bluetooth Headset
I had to buy a new cell phone [droid] as my previous one was damaged. Although connected my NUVI 760 it will not down load the address book in the cell phone. What am I doing wrong??
Connect your 760 via USB to your computer and go to www.garmin.com and hover your mouse on "Support" and then click "Software". Select "Webupdater for Divice Software" and follow the directions to download updates for your 760. Keep in mind, not every cell has the same level of supported features, so some things that worked through your 760 on your old cell may no longer work with your new cell. If you have further question, click on "Contact Support" to get factory help.
I hope this helps!
May 20, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
I have a problem reconnecting Nuvi 765T GPS to Blackberry automatically. Every time there is a message on the phone "Do you want to connect to Nuvi" "yes" or "no". Is there any way to avoid it? May be...
Turn off the prompt that appears when connecting or pairing
1. In the device options, click Bluetooth.
2. Click a Bluetooth® enabled device.
3. Click Device Properties.
4. Set the Trusted field to Yes.
5. Press the Menu key.
6. Click Save.
To turn on the prompt again, set the Trusted field to No.
Hope this helped.
Nov 18, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Garmin nuvi 760 can't turn on
This morning I try to plug the unit into computer and find out it is out of battery power. I recharge it and it back to normal. Thanks for the following up with me.
May 17, 2009 | Garmin nuvi 750 GPS Receiver
Pairing bluetooth motorola W755 phone to Garmin nuvi 760
I left the Garmin in passive mode and had just the phone do a search for new bluetooth devices and it worked fine. So my advice is , if the Garmin instructions don't work, try this method.
Apr 01, 2009 | Garmin Nuvi 760 Car GPS Receiver
Alternate Power Options
my blackberry charger charges my 760 w/o any problems.
Jan 19, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Pairing my garmin nuvi to my blackberry
Nuvi 200 does not have bluetooth capability.
See this link:
https://buy.garmin.com/shop/shop.do?pID=9160#specsTab
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 760 Blutooth pairing
I also have the 760 & the first gen Boulder (before the front speaker was added). I had the same issue with the M07 firmware (the latest you can get over the air), but took it into a Verizon store & updated it to M09. I am now able to pair the two devices.
Jan 04, 2009 | Garmin Nuvi 660 GPS Receiver
Pairing the Garmin Nuvi 660 with my Verizon LG Voyager
yes your phone will work with this unit i have hooked up plenty of them .... if you have any problems contact me and i will help
thanks nate
Aug 25, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 760 phone feature
Did you check the settings for the sound output? If it is set to FM-receiver, you have to tune your radio to the same frequency as the 760 transmitting frequency. To get sound from 760-device, you must deselect the FM-transmitting feature.
(I don´t think this solves your problem. Too obvious.)
Jun 26, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
