Question about Bosch Dishwashers
Bosch S9GT1B not taking water
I have a problem with my dishwasher. It's a bosch economicstar. It takes no water in, tap is on, no kinks in lead, it just stopped taking water. It does go through the program normally and does try to pump the water through the arms. It also drains the water perfectly well. I used it for the last week by adding water 3 or 4 times per cycle whenever I heard it sucking water for the cleaning arms. I opened the left side of the machine, where the water inlet/outlet is. I wanted to check whether the waterlock was broke so I disconnected the water inlet hose from the big seethrough reservoir and switched the machine on. After pumping out the remaining water, therewas water coming from the inlet tube. I reconnected the inlet hose and switched it on again after a rset. Now it did work fine. I switched it off, reset the machine and switched it on, no water again. I repeated this, and after disconnecting the inlet hose it worked agsin. Unfortunately only once... Any advice???
  • 121 Answers
Check electro valve,water-level switch.
Posted on Feb 15, 2009
Water comes into dishwasher cold. why???
Welcome to FixYa.
Have you insured the unit is connected to a hot water supply line ? The water will not heat until it start's to circulate and activates the "flow switch" in the Bosch dishwashers.
If it is connected to a hot water supply, try running the hot water at your sink taps before turning on the dishwasher. If you still do not have hot water, check your hot water heater or supply.
If it is indeed connected to a cold water supply it will work, just be prepared for very long wash cycles since the Bosch machines will heat the water at a rate of 2F per minute...it could take a long time to reach 155F.
Let me know what you find out and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch 23 in. SHU33A Built-In Dishwasher
The water in the dishwasher isn't draining away
CHECK DRAIN HOSE FOR KINK DIDI U JUST INSTALL NEW DISPOSAL IF SO TAKE OUT DRAIN PLUG OR PUMP BAD STUCK SEAL
Jan 07, 2011 | Bosch SHU5315UC Dishwasher
Dishwasher instructions
Hello, welcome to Fixya.
Typically the "normal" wash cycle should be sufficient and take anywhere from 60min to 120min. under normal conditions. ( Though 120 mins is quite long and should only occur if you had a low hot water supply, i.e. many people showering at the same time ).
The one variable in this is "normal". These machines when connected normal or proper should have a hot water supply and a heating capacity of 2 degrees per minute until reaching 150 degrees.
The other "tip" to consider is the numbers in the display ( depending on the model...not all have led displays ) is not actual time, just estimated time based on the previous cycle.
If you select a normal wash and run the hot water tap at your sink before starting the machine and it still takes in excess of 2.5 - 3hrs. to complete, there's likely a heating problem.
Let me know and we can go from there. The B/S/H/ ( Bosch, Thermador, Gaggenau & Siemens ) dishwasher's have had some issue with the heater relay on the control boards dating back to the early to mid 90's. Just browse through the bosch dishwasher problems and solutions under my profile... http://www.fixya.com/myprofile/solutionsfiltered.aspx?ctgid=131&usrid=3604823
and you'll see what I mean.
Thank you for visiting "fixya", please take a moment and rate the info I provided for you here and also let me know if you require any further assistance.
Good luck.
macmarkus :)
Jul 05, 2010 | Bosch Dishwashers
Bosch dishwasher will not fill with water
I MIGHT BE GIVING THE OBVIOS ANSWER BUT ALL PIPES MUST BE FREE FROM KINKS,AND THE OUTLET PIPE SHOULD ALSO BE AT A CERTAIN HEIGHT FOR WATER TO DRAIN.
[I PRESUME WATER TAPS ON CONNECTION PIPES ARE SWITCHED TO ON POSITION.
Nov 09, 2009 | Bosch Dishwashers
Check Water Supply display lights up
It sounds like there is a filter or screen on the water inlet that is partially clogged, check for that.
May 17, 2017 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch wont
Faulty inlet valve or water in the bottom tray which will activate the float swich and pump out any water. See that this moves up and down freely. Turn electrics off first.
Jun 18, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water supply to dishwasher
is the tap on? is the inlet hose kinked ?.hard to know without seeing it.hope this helps.
Mar 23, 2008 | Dishwashers
Bosch shv55mo3gb
use this link then click on insruction manual download type in the model number remember 0 is a number.I know that sounds condesending but i forgot. I used the manual with the ending aus.
http://www.bshappliancecare.com/Bosch/Bosch_dishwasher_manual.html
Mar 22, 2008 | Bosch 24 in. SHV55M03GB Built-In...
Dishwashers Logo
1,462 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
