Question about Kenwood VR-406 Receiver
Centre speaker my centre speaker worked then stoped so i played with some controls got it working again (6months ago) now it stopped working again can any 1 help me
  • lp_rulz_lp1 Feb 16, 2009
    thank you so much for your help and thank you for the fast responce
Well if it isnt my little sister hows it going crystal
Posted on Jan 29, 2010
    Scholar:
  • 93 Answers
The controls I would check are speaker set-up and configuration for a multi-channel sound, be sure to enable center channel YES/NO option and trim center channel level output.
Posted on Feb 15, 2009
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Right side of headphone stoped working
you need to open the broken side up and re solder the cable back also check the other cable to see if it hasn't sheered off inside the insulation like mine did. Hope this helps. J
Feb 17, 2013 | Philips SHB9100/00 Bluetooth Stereo...
I have been using my lg ht534sn for about 4weeks but after moving it from its fomer place to another the centre speaker and 2 other rears stoped working but but if i test all the speakers they work but...
Hi samuel
You said connections are good. Once check at both speakers and amp side for perfect contact or remove existing wiring for those speakers and re-fix. Also check for the levels individually in your HTS, also the mode you are currently in.
-sai kumar
Dec 28, 2010 | LG (SP4200K) Speaker
Speakers stop working
This is either a loose connection internally or a dirty control such as the volume control. Both of these will require a trip to the shop
Apr 04, 2010 | Sony STR-DE697 Receiver
Maytag mde9206azw wont start
sound like the pulley need to be removed.
this information will let you know how the pulley look like n gives you the price
http://www.partselect.com/AppliancePartList.aspx?Brand=Maytag&Appliance=Washer&ModelNum=&Type=Pulley%20-%20Roller%20-%20Axle%20-%20Bearing&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
was this helpful?
May 11, 2009 | Maytag PYE2300AY Electric Dryer
Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
My right speaker from my z-2300 stop working.
sounds like a loose connection somewhere inside that particular speaker. You could open it up to check for a loose or separated solder joint. The safe option would be to return to place of purchase and exchange for a new set.
Apr 14, 2008 | Logitech Z-2300 Computer Speakers
Loss of sound to Logitech Z560
I repaired Z-560 speakers with a defective left front channel by chopping off one of the input leads close to the 3.5 mm stereo jack that goes into the PC and joining on the leads from a new one. At first I thought the fault lay in the main amplifiers in the sub woofer unit but I was wrong and it turned out to be far simpler to fix than I anticipated.
Rod in Ottawa
Aug 27, 2007 | Logitech Z-560 Computer Speakers
Kenwood VR-406 Receiver Logo
150 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
