Question about ASUS P4P800S-X (610839118175) Motherboard
My pc don.t start normaly after i close it for a long time
When i close my pc for a long time like in the week end
and i come back my computer not start normally
    Problem Solver:
  • 10 Answers
You will have to go into more detail but if your saying it won't power up without a message that requires you to go into BIOS before restarting then your motherboard battery is bad and needs replacing. I've installed 2 ASUS motherboards and both had weak or bad batteries.
Posted on Feb 15, 2009
When i start my laptop it strat resuming window and the log off . if i place f8 the key don`t work why? help me please
If it is resuming windows each time, it is not being switched off. Press the Start, go across to the arrow next to the Shut Down box and choose Log Off from the menu. Then click the shut down or end button bottom right of desktop to close it down completely.
F8 only works as the system starts to boot.
Dec 10, 2013 | Fujitsu Siemens Computers & Internet
My Compaq Presario computer does something very strange. Every day, several times a day when I am online computer light turns amber and it starts screeching. I can not continue using Internet when it...
Sounds like it is overheating. Pull the side panel off of it, clean the fan blades and vents. 3am may be the time that it looks for updates.
You may also want to download a free version of Super antispyware as well as malawarebytes, just to make sure you are not infected. These two programs together will remove problems that other virus software will miss!
Jan 14, 2013 | Alienware PC Systems Computers & Internet
How can i get an acer aspire 5100-3357start normaly without a ethernet cable after resetting back to factory
You don't need a ethernet cable to start a computer. Ethernet cables provide internet connectivity. Exactly what is the problem you are having?
Apr 23, 2012 | Acer Computers & Internet
It is a 1996 front wheel drive continental, the problem is that it will start normaly for a few weeks, then you try to start it and it just sit there and lets you crank away and it will not start. If you...
with new fuel pump and filter, I would suggest looking at the electronic ignition.. sometimes when they go "bad" they work sometimes and don't at other times.. frustrating for sure..
Mar 11, 2011 | 1996 Lincoln Continental
How do I increase the speed?
there are several ways to increase your computer's speed.
first, find out best anti-virus for your system
second, use (or upgrade =increase your ram size )more then 512 mb ram
third, stop unwanted application on taskbar
fourth, find out these applications which are start with windows and then stop it.
fifth, remove unwanted file from c drive which is usualy we keep for operating system drive, make sure it has enough space or make your drive bigger , at least 20 gb for c
sixth, remove unwanted program from your computer(controlpanel>add remove program)
seventh, scan your computer at leat 5 to 7 days (every week)
last, open only two or three apps at a time if you want, don't open unnecesorry at time, close all these if u don;t need it.
now if you try above things and even after these efforts you need to use new pc.
Jul 10, 2010 | Dell Dimension 3000 PC Desktop
Cant get this gaming program i downloaded off internet explorer
use a antivirus scanner and reset ie to defaults. normaly is a spyware infection.
Feb 09, 2010 | HP Pavilion dv6000t Notebook
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Windows error recovery
Hello!!
enter the repair the console by inserting the Xp cd.. and try the command FIXBOOT .. and then restart!!:)
Cheers!!
May 31, 2009 | ASUS G1 Notebook
Black screen with only mouse pointer
well try to start pc in safe mode you can do this by pressing F8 key at windows startup after this remove your display(VGA) driver from device manager and then try to start window normaly if its start normaly then you have problem with your VGA.
And if its does not work then try to reinstall your windows
some times Asus and Msi motherboards have this problem,do nt know wthats is yours
hope you have got answer
regards,
Ali
Oct 30, 2008 | Computers & Internet
Photo Exploer Runtime Error
My solution:
I found another solution(workaround) instead of reinstalling the program:
1. Try to remember wich devices you used in de Photo explorer (USB-stick, external drive, DVD- CD-drive, or photo-camera connected by USB;
2. You can only start PEX(Photo Explorer) with a volume loaded in this devices!
3. if you don’t remember wich devices you used before, plug in a volume in every device your system has.
4. Start PEX. On my system it is then starting without error!
5. If PEX is normaly started: goto File/Preferences/ (or F6 key), take category Cache and under “History” clean all adresses and maps by clicking the button.
6. Close PEX. Remove all the volume’s you don’t need;
7. Restart PEX. Now the program will start without any error.
8. Advice: each time you use PEX with an external device do action 5. before closing the program.
Mar 26, 2008 | Nova Development Photo Explosion Deluxe...
ASUS P4P800S-X (610839118175) Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
