Question about Bosch 24 in. SHU53 Built-in Dishwasher
Replacing the heater unit in a Bosch dishwasher SGS43e02
The heater unit needs replacing in my dishwasher (I have proven this using a multimeter - it is not the circuit board or underfilling).
I have the new heater unit in my hands but it seems very hard to get access to where I need to get to fit it.
Is there any shortcut access or do I have to do a major dismantling job on the machine? If the latter, what is the best sequence for taking it apart? Do I have to turn the machine upside down or on its side to access the heater? Any hints and tips?
Thanks,
Rob
I have just finished changing the heater on my Bosch SGS55C02GB. It is a tricky job but fixed my problem for £100 instead of paying £350 to replace the whole thing. My model had no access hatch to the heater, as described by the previous solution, the only way to get to it was to take the whole plastic bottom off the unit. After reading other posts on other forums, taking the bottom off seemed like a nightmare job, so instead, I cut out a hole in the plastic tray with a jigsaw and created my own access. Obviously had to be vary careful not to cut any wires or pipes! This allowed me to actually get to the screws to undo them, and swap the heater for the new one. The only extra part I needed was a new jubilee club to replace the original one that attaches to the pump. The part I replaced was:
http://www.ransomspares.co.uk/parts/dishwashers/neff/instantaneous-water-heater/220088.htm
Posted on Jan 27, 2011
Hi
I had first tried to fix the heater problem by following the advice to look at the relay in the control unit and to re-solder the faulty joint - I did this but it still did not work so I bought a new heater unit instead
I have now just replaced the heater unit in my machine - its simple if a little fiddly
first switch off power to the machine just in case!
If it is a "flow through" type do the following:
remove the metal panel at the bottom rear of the machine held in place by two self tapping scews with a "star" head on them - you will need a special screwdriver for this as slot head or "Philips" type wont work
remove the thin metal panel and you will see the heater unit to the left
it is held in position by the two pipes to which it connects - in my case a cream/semi-transparent pipe on the left and a black rubber pipe on the right
they attach to the heater by two clips - you will need a pair of mole grips of pliers with wide enough mouth to squeeze the clips together and slip them back along the pipes so that you can pull the unit off the hoses - just make a note of how they looked and were positioned so that you can put them back in exactly the same place!
then remove the electrical contacts but just note where they go before doing so - this is the fiddly part but just rotate the unit slightly to expose them so you can pull them off - it s ok you cant break anything by giving them e bit if a tug!
then remove the unit and slide the hoses over the ends of the replacement - attach the two connectors - slide the clips back into their original positionand just check that it is all secure and the hoses are properley on as far as they will go
replace the panel and then connect to power and it should now work
hope that helps
Posted on Feb 15, 2009
  • mccarr Feb 15, 2009
    Not sure if you ggot this so am re-sending in case - good luck
    MCC
    Hi
    hope that helps
Any ideas what I should replace? Do I just replace the control board? Would that one relay cause the whole dishwasher to have no power?
If you have a multimeter set to continuity and see if it burnt out you might be able to replace it at an electronics part place also see if there are any fuses in there
Jan 26, 2015 | Bosch SHU5315UC Dishwasher
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Can you advise what amp rated fuse is to be fitted on ther plug
Hi, You will need to fit a 13amp fuse the the plug for this appliance.
Hope this helps.
Feb 12, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
SGS43E02 dishwasher is blowing the fuse but I can't get into it to see what might be the problem, how do I remove the top and side panels to gain access.
You normally have to remove the back panel to gain access to the other panels. The order is usually, the back panel first, then the top panel and then the side panels. The top panel may be held in place by two screws and then slides backwards to come off.
Feb 06, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
My dishwasher does not do a hot wash. Why is this? If I need to replace the heating element, how do i gain access to heating element on my Bosch classixx dishwasher?
Hi, a common problem with these machines is the solder coming away from the heater relay. A simple repair if your lucky. Run a continuity test on the element with a multimeter before replacing it, as it is a massive job to change it. I just changed mine yesterday, the machine had to be totally stripped down. Although its not an impossible task, it does take some time. A kindly man on this site sent me a manual for Bosch dishwashers, which helped me enormously on stripping the machine down. I don't know if it is any good for your machine, but if you give me your email I will send it on to you. Mike :)
Nov 29, 2010 | Bosch SHU9950 Dishwasher
Bosch SGS43E02 will not drain - otherwise seems fine Any help? Thanks
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 07, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My bosch dishwasher is about 4 years old. It gets
Hello, This sounds like, based on your description, the unit has a faulty heater relay. The issue with Bosch dishwasher`s most times lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever top finish ( because it can`t heat to advance or until canceled ) trying to heat the water. **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony. Good luck. macmarkus :)
Apr 05, 2010 | Bosch Dishwashers
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
475 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
