Question about Nintendo Wii Console
Wii lights dont glow after install
I bought a wii console in US and assumed it will work in India with 220 to 110 V converter.
My son enthusiastically operated in my absence before the converter was put in place.
I would like to know if there are any services available in Bangalore, India to repair the device.
  • 42 Answers
You might be OK. It sounds like the power brick died. The power brick sends only 5v/12v DC power to the unit. You most likely have fried the power brick and I would recommend borrowing a friend's to test. This should resolve your issue.
Posted on Feb 15, 2009
Nintendo WII
Wires that do not come with the Wii fail. Always use the one that comes with the Wii.
Jun 27, 2013 | Nintendo Wii Console
I stay in India and bought a wii console from Singapore . Recently bought Mariokart game ( with Wheel ) from Dubai duty free . The wii console cannot read the disc - what can i do to make it work ?
If the disk is dirty, you may try to clean it. Rub a small amount of toothpaste gel onto the disk with your fingers, rinse with luke warm water, and dry thoroughly before putting back into your Wii.
Verify the problem isn't with the Wii itself. Make sure that the Wii you purchased will play a different game. (Wii Sports would work fine.)
If the game disk is a pirated or burned copy your Wii has to be modified to read those disks.
Apr 10, 2011 | Nintendo Wii Console
I had bought a new nintendo wii from america and when i used for the first time in india there was apower fluctuation and bam my wii is not working what is the problem?
i believe the voltage in India is in the 230-240 volt range here in America around 110 volt if that is the case you might need to talk to the Nintendo repair center http://www.nintendo.com/corp/distributors.jsp
i wish you the best of luck
Dec 02, 2010 | Nintendo Wii Console
I too have the same problem
Well like you said, USA and India.
Did you check the power voltage from usa compaired to India? You might have just blown your system if you didn't pay attention to that.
It's not recommended to take outside of usa, but if you do, you should have bought a power converter/adapter.
Sep 07, 2009 | Nintendo Wii Console
Console will not turn on. light is neither red or
Since you said the light isnt red or green im assuming its not glowing at all, and in that case you most likely over worked your adapter like i did. All you need to do is unplug the cord thats connected to a gray box from your Wii, and follow the cord out the other side and unplug it from the wall. The gray box is the adapter and if you leave it unplugged for a couple hours then hook it back up to the wii, the light should come back on, although in my case the light is now yellow when its off instead of red.
Aug 14, 2009 | Nintendo Wii Console
Our wii console won't turn on. The power button doesn't even glow anymore. What's wrong with it?
it might be a problem with the power converter. make sure the wall socket the wii is plugged into is working properly and you don't have a broken fuse somewhere. try a different plug to see if you can get the wii to power up at all, if not you might need to buy a new power cable.
Jul 31, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Nintendo Wii console gets a black screen when switched on
not to be mean but buying a modded anything usually voids the warranty.
Not having anything to go off of regarding the mod means that we don't know if it's a faulty weld on the board or anything like that.
Try doing a system reset (if there is a reset button) and see if that works
Jun 08, 2008 | Nintendo Wii Console
Wii
check wii console is connected then insert wii fit cd and see what happens put new batterys in remotes and make sure wii works before installing wii fit
May 26, 2008 | Nintendo Wii Console
Blue light
All we did was hit reset on the Wii system while on the Wii main menu.
Feb 27, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
108 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
