FixYa.com
Tags:
Datamax Printer
Datamax printer problem
By jessie25 - usenet poster
I am unable to get my datamax E4203 to work. I can install it as a windows
printer and it works fine. When I try to install it as a generic text printer
it doesn't print at all. I really don't want to use an additional program to
be able to print my RMS labels.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Got it working as a windows printer, thanks. Now I have a new problem. I have
used 3 of 9 barcodes for all of my 8000+ look ups. Unfortuately this is not
in the list of barcodes available for the printer. Also I find the quality
of the label editor to be quite lacking. Is there anyway to create my labels
outside of RMS and import them?
"Glenn Adams [MVP - Retail Mgmt]" wrote:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
JimK,
The barcode selection is tied to the item, not the printer. Look at the Item's properties on the General tab.
Just make sure to have enough room for the barcode on the label
Jeff
Check Point Software
You must be using Outlook Express or some other type of newsgroup reader to
see and download the file attachment(s). If you are not using a reader, follow
the link below to setup Outlook Express. Click on "Open with newsreader"
under the MS Retail Management System on the right.
Solution #3
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
JimK,
Don't go on what the other label looks like, see if it scans. Go into Notepad, scan the label and see what appears on the screen.
I don't know what size label you're trying to use, but here is a 1.125" x 3.5" label we've used for a Dymo printer using the Windows driver and RMS' label designer. Try it and modify in the RMS Label Designer as you need.
Otherwise, try to just create a label with _just_ the ILC and a barcode and add from there.
Jeff
unfortunately the barcode it's printing is not the one tied to the item. It
looks nothing like the one printed with our other printer, a cognitive bar
code blaster generic text printer. Of course this is using a different label
format as it's not installed as a windows printer
"Jeff @ Check Point Software" wrote:
Dymo 1.125 x 3.5.lbl
2K
Solution #4
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
Solution #5
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
I'm not familiar with that printer, but if you can set it up with a
Windows driver, you can use the label editor built into RMS to design
your labels.
Glenn Adams
Tiber Creek Consulting
Please DO NOT respond to me directly but post all responses here in the
newsgroup so that all can share the information.
Can you Help with these Printers problems?
Printers
Recently our Windows XP went
Recently our Windows XP went... Answer This...
Printers
Epson DX8500 all-in-one printer...
Epson DX8500 all-in-one printer... Answer This...
Datamax Printer
cutter not lining up
ST3210-We use these ticket... Answer This...
Datamax Printer
HELLO
i try to installed dalamax... Answer This...
Datamax Printer
DATA MAX PRINTER
Error: Number:-2146828235... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
