Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Fan roller and grey fins clogged with dust and mould
We have a Mitsubishi Spleit inverter air con 3 years old model MSZA30KIT 8000/9000 R410A we would like advise on how to clean the inner fan roller
  • 56 Answers
You can clean Blower wheel one of two ways. !st would be to remove the wheel and clean with the garden hose or if that is not a option for you then you can buy a can of compressed air and clean it that way but you will get a blast of dust and dirt when unit turns on. Make sure unit and/or power is of when doing this. Keeping your filter mainteneced more often will reduce the build up more.
Posted on Feb 16, 2009
I have a R410A Inverter Split system that has stooped suddenly and is now displaying E1, what does this mean/ Thanks Lorena
Not 100% sure but an E1 error on a unit which is sourced from the same place as Electrolux air cons, means that the pipe sensor on the indoor unit has failed. You will need to confirm this with Electrolux. They carry a 5 year warranty, so you may be in luck.... hopefully
Jul 16, 2011 | Electrolux Heating & Cooling
15 year old bath fan/light noisy. rectangular 2 bulb model 164A-D
Could be that dirt and dust have collected on the fins over the years and are throwing them out of balance. You could try cleaning the fins on the fan.
The bearings may also be wearing out.
15 years is a good life for a fan.
May 03, 2008 | Broan-NuTone N-8664RP Combination Light...
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Hi my bmw 523 model 1997 the air con fan is not
clogged fan with debris. bad resistor or 3. remove fan, run 12v directly to it to see if it spins. plenty of threads w/pics on how to do this.
Jul 17, 2010 | BMW 525 Cars & Trucks
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Gateway 340UI Overheat
Well, I can tell you this. With most laptops the fans **** in air and blow it into some copper fins. These fins are very close together so dust and dirt clog the the air flow over the fins. Try this, get some canned air and go outside. Look for the copper fins (should be where hot air use to come out). Use the air to blow out the dust. Also blow air into the fans. Good luck.
Jun 23, 2009 | Computers & Internet
Mitsubishi TV air flow
open the back of the television to check for dust buildup on the heat fins and other components. As well as the fan.
Mar 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi r410a model puya30ma manual
where can I get a manual so that my husband stops hissing at me for misplacing it?
Jun 28, 2008 | Mitsubishi Heating & Cooling
Dehumidifier
if the fins feel cold then you should be collecting condensate. so try this: remove the outer shell to access the fins. with a garden hose, spray the fins off thoroughly. you may see a lot of dust and line that was clogging the air flow.
Jun 03, 2007 | Fedders A7DH65B2A Dehumidifier
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
800 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
