Question about Dryers
Hotpoint aquarius vtd20 not heating
Dryer is turning fine but just not giving out any heat. the vent is clear. any suggestions??
  • kennybenny Feb 15, 2009
    Hi Mike,
    I have had the whole dryer in pieces. the 2 kind of 'micro switches' ( whether they are tco or something) in the back panel that come straight off the heating coils. when i put a meter across one of them and press the button it switches open closed on the meter, and the other one doesn't switch, open closed, constantly at 60 ohms closed. could that be the prob?
    Genius:
  • 1,122 Answers
Sounds like the heating element is bad or the heater box fuse and thermostat one of the 2 is bad,if you have a meter you can check all 3 on the ohms setting,let me know-mike
Posted on Feb 15, 2009
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fjj
Feb 15, 2009 | Maytag SDG4606A Gas Dryer
Drying time on aquarius vtd20
The timer is an electro/\mechanical one , and is usually non repairable, the only thing you can do short of replacing it, is to remove the top cover, and clean away any fluff or dust that you can see, and spray inside the the unit with wd 40.
If this does not solve the prob, then you will have replace the timer complete.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
HotPoint Elec dryer heats up but doesn't dry
yes you have a vent restriction something is blocking your airflow it needs to be an open 4 inches all the way and clear describe your vent to me are you using plastic behind the dryer is it short or all mashed up don't move the dryer get a flashlight and look over the back like its sitting and describe your vent to me from the dryer to the out side if its plastic and looks like a python then you may have found your promblem
Mar 31, 2008 | Hotpoint TDC32 Electric Dryer
Dryer keeps cutting out
Dryer outlet hose could be plugged or restricted not letting adequate air cirulate. Check this and the filter to be sure both are clear of obstructions. Make sure the flapper at the end of the dryer vent is working correctly.... A blocked vent will cause the temp to get too high and the unit shuts down rather than burn down the house.
Jan 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
231 people viewed this question
Top Dryers Experts
