Question about Maytag SDG4606A Gas Dryer
Hotpoint aquarius vtd20 not heating
The dryer is turning fine and the vent is clear im just not getting any heat. any suggestions??
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fjj
Posted on Sep 30, 2010
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
sounds like the heating element is bad or the heater box fuse and thermostat one of the 2 is bad,if you have a meter you can check all 3 on the ohms setting,let me know-mike
Feb 15, 2009 | Dryers
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
HotPoint Elec dryer heats up but doesn't dry
yes you have a vent restriction something is blocking your airflow it needs to be an open 4 inches all the way and clear describe your vent to me are you using plastic behind the dryer is it short or all mashed up don't move the dryer get a flashlight and look over the back like its sitting and describe your vent to me from the dryer to the out side if its plastic and looks like a python then you may have found your promblem
Mar 31, 2008 | Hotpoint TDC32 Electric Dryer
Dryer keeps cutting out
Dryer outlet hose could be plugged or restricted not letting adequate air cirulate. Check this and the filter to be sure both are clear of obstructions. Make sure the flapper at the end of the dryer vent is working correctly.... A blocked vent will cause the temp to get too high and the unit shuts down rather than burn down the house.
Jan 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Maytag SDG4606A Gas Dryer Logo
122 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
