Question about Canon iR 1600 Laser Photo Printer
How to set
Sir my ir 1600 is working because i have reset it? my paper size is 11x13? how to set for that paper size?
  • MOHANWOO Feb 26, 2009
    sir my ir 1600 is NOT working AND GET ME MASSAGE INCORRECTING PAPER SIZEING? my paper size is A4? how to set for that paper size?
    President:
  • 2,692 Answers
Find your printer on the Canon website and download a manual for instructions.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Posted on Feb 15, 2009
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Sir, i have question- error code E000 IN CANON iR 1600 i have copy macheine i wsh you help me
E000 : fusing problem ,check the thermistor, therm fuse and heater lamp then try to reset it by reset error code.
Jan 15, 2011 | Office Equipment & Supplies
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Canon IR 2870 A3 printout tail crumpled
Hello sir; When you print A-3 size paper did you set up on computer for a-3 size paper, most case A-3 size use in europe, usa use letter size. I hope that's the problem,
Jan 29, 2010 | Canon Office Equipment & Supplies
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Blurry bottom 2 inches of copy from IR 1600
Take a Normal,reduction and an enlarged copy(at any ratio) of a Newspaper in different size papers. Then check whether the blurred position is at the same position or not.If it is at the same position, check scanner for its free movement, there may be an obstacle which will not allow the scanner to move freely resulting in blurred copy. or else let me know.
Dec 27, 2008 | Canon ImageRunner 1600 Copier
IR 5000-6000 LGL TO A4 PROBLEM
What country are you from ???? here in the US we do not use A4.
Only Legal Letter, check the size of the paper you are using and check the trays to make sure it is set correctly.
Oct 11, 2008 | Office Equipment & Supplies
Regards DADF size setting in ir4570
Are you sure the problem is not coming from the paper tray????
Open the paper tray and look at the guides that hold the paper, if Letter paper is in tray make sure the guides are set against the paper, also look "behind" the tray for paper it could be changing the paper size.
Oct 03, 2008 | Canon imageRUNNER 4570 Copier
Canon iR 1600 Laser Photo Printer Logo
287 people viewed this question
old marine
old marine
