SOURCE: Cannot back up DVDs on LG Super Multi 20x DVD rewriter
You definitely should call LG--your new gaget isn't working, and it is under warranty. Or try going to their website to see if they have any software upgrades--sounds like you have a bummer, and perhaps a reinstall from their website will do the trick.
SOURCE: Need Vista driver for external DVD writer of LG model GSA-5169D
There aren't any such drivers. The drive control protocols are standardized. Just do Windows Update a few times and make sure the thing's connected when you restart storage subsystems (pretty much a reboot; though installing Nero will of course get things going if you don't love Vista built-in tools.)
SOURCE: LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
SOURCE: LG GSA - H55N not able to VIEW contents
1. Start > Run.
2. regedit
3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4. Select File > Export
5. save the file to the Desktop in case you need to restore it
6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
7. Do the same for the UpperFilters line
8. Close the Registry Editor.
9. Restart Windows.
