Question about Adobe Computers & Internet
Unable to load post script fonts in windows-xp
How to load Post script fonts (.pfb font files) in Windows-Xp?
  • 24 Answers
Well postscript fonts are vector outline fonts, so they contain instructions about the building of their outlines and curves and such. Hence two files are required to use a postscript font under Windows.
As to how to install these fonts, well
  1. Click Start | Settings | Control Panel.
  2. Double-click on the Fonts folder.
  3. Choose File | Install New Font.
  4. In the Folders menu, navigate to the folder containing the fonts that you wish to install. A list of available fonts will appear in the List of Fonts window.
  5. Click on the font you wish to install or use the "Select All" button to install all fonts in the List of Fonts.
  6. Click on OK.
Please keep in mind:
  1. If you are installing fonts from a CD be sure the 'Add without copying files' box is NOT checked; unless the fonts are on a located somewhere (such as a network) which you will have access to at all times.
  2. Postscript fonts have two files: PFB (printer font binary has outlines that control how the font looks) and PFM (printer font metrics has information about font spacing). Be sure you have both font files.
  3. If you currently have or previously had Adobe Type Manager Deluxe 4.0, 4.1, or 4.1.1 installed you may need the Adobe Deluxe Updater in order to properly use your Postscript fonts under Windows XP. Get it from Adobe.
Hope this helped. Let me know and if yes please rate me:)
Posted on Feb 15, 2009
Install tamil font
Yes you can install Tamil font on your computer by following method.
First download the tamil fonts, then if you are using windows 7 OS select all your fonts and right click on them and select install option. Thats all.
If you are using windows XP PC, you first go to control panel - Fonts - then select - File - and then select - Install font and select your destinatination where your fonts saved and select all install them
Dec 29, 2013 | Adobe Acrobat Pro XI for Windows
Tip
Overcoming Font Overload in Windows
We all like to install fonts however when the number gets above 1,000 your PC will start to SLOOOW down loads this will also slow down programs that use system fonts like Adobe Photoshop so it's a good idea to keep the number of installed fonts below 400. If you do this you will find your system and programs will start faster and run much smoother.
Does this mean you have to give up all your favorite fonts? Not necessarily... There are a few things you can do to have the best of both worlds. The best way is to use a fontmanager there are a few here are some of the best
Font Frenzy has the added use and will allow you to revert back to system defaults, otherwize use this procedure posted at FileFrontForums
Fonts Utilities
Bitstream Font Navigator (Corel)
Font Frenzy (Sound Doctorine Ministry)
Shelltools (Moon Software)
Adobe Type Manager Lite (Adobe)
Fix Font Folder (High Logic)
Font Viewers
NexusFont (Xiles)
AMP Font Viewer (Ampsoft)
Advanced Font Viewer (Styopkin)
Microsoft Typography Tools
Font Validator
OTF File Extension
Web embedding fonts tool (III)
on Mar 14, 2011 | Microsoft Windows XP Professional for PC
How can type rupee symbol in keyboard
1.Download the file on this link http://blog.foradian.com/rupee-font-version-20
2.Copy the file to C:\Windows\Fonts directory.(for Windows XP users)
3. Right-click the file and choose "Install". (for Windows 7/Vista users)
Jul 06, 2012 | Lenovo Keyboard
I have a 64 bit computer and I am trying to install Parsons Hebrew Tutor which is an 8 bit program. Is there anyway possible to do this?
What OS were you previously using with the program? This program ran well under Win98 but could run in Windows XP. This is for the version released in 1997. Some reviewers noted problems with the fonts, screen resolution and color attributes under XP.
I think the only way you might be able to run the program is in a second computer (physical, dual boot or virtual). What OS are you currently running? If you have Windows7 Pro or Ultimate, you can run a virtual XP for free. (If you have Home Premium, you can upgrade to Pro or Ultimate for a fee.) Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the Hebrew Tutor on the XP computer. You may need to copy the fonts to the System font folder (either from the tutor disk or the folder that is installed with the Hebrew Tutor program)
To install a font, follow these steps in the XP system:
  1. Click Start, and then click Run.
  2. Type the following command, and then click OK: %windir%\fonts
  3. On the File menu, click Install New Font.
  4. In the Drives box, click the drive that contains the font that you want to add.
  5. In the Folders box, click the folder that contains the font that you want to add, and then click OK.
  6. In the List of fonts box, click the font that you want to add. To select more than one font at a time, press and hold the CTRL key while you select each font.
  7. Click to select the Copy Fonts To Fonts Folder check box. The new font is saved in the Windows\Fonts folder.
  8. Click OK.
(Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. If you decide to run the program under Windows 98, you will not be able to use the XP mode. Instead you will need one of the other options I have listed.
I hope this helps.
(if you are running a UNIX or MAC OS, you can do something similar with a virtual computer. For UNIX try WINE (which runs many Windows programs). For a Mac, you will need a virtualization program and a licensed copy of Windows XP.)
May 05, 2011 | Parsons Hebrew Tutor (9781572640610)
Hi. How am I supposed to install new fonts under Windows XP Professional?
Glad to help YOU!
If you want to install new fonts you have to follow these steps:
1. put all your font you would like to install into a file (just do in C:\ a new folder named 123 or the way you like) because it will be much easier;
2. go START > CONTROL PANEL;
3. double-click on FONTS icon;
4. once the window appeared fo FILE > INSTALL NEW FONTS and BROWSE to the folder you have put all your new fonts;
5. click OK and let Windows XP to install all your fonts.
It's done!
GOOD LUCK!
My best wishes!
Mar 13, 2011 | Computers & Internet
I want to install arabic languish to windows XP but no CD
You can do it by directing the windows to the folder c:windwossystem32dllcache and after that it asks for some special type of files like help files which can be igmored, and font files and you can either download them one by one or you can search for a compressed file that contain all of the font files.
For a detailed procedure you can follow the link.
Dec 14, 2010 | Microsoft Windows XP Professional for PC
I want gujarati & hindi fonts for MS word file .From where can I get it?
1. Need to download all the hindi font from the site http://salrc.uchicago.edu/resources/fonts/available/hindi/
OR
Instructions Things You'll Need:
  • Microsoft Office CD or DVD
  • Windows installation CD or DVD
  1. Click the "Start" button, then click "Control Panel."
  2. Double click "Add or Remove Programs" if you are running Windows XP or "Programs and Features" if you are running Windows Vista or 7.
  3. Click the program list entry for the version of Microsoft Office that is installed, then click the "Change" button.
  4. Select "Add or Remove Features," then click "Next" or "Continue."
  5. Click the plus sign next to "Office Shared Features" to expand the category, then expand the "International Support" category.
  6. Click "Hindi Font" or "Universal Font" depending on the Office version, then click "Run from My Computer."
  7. Click "Continue" to finish installing the font. Insert the office disc if prompted, then return to the Control Panel window. If you are able to view Hindi fonts in Word, stop here. If you are not, you may need to enable support for complex fonts in Windows. Continue to the next step.
  8. Double click "Regional and Language Options."
  9. Click the "Languages" tab, then place a check in the box labeled "Install files for complex script and right-to-left languages." Click "OK" twice. If you are prompted to insert the Windows installation disc, insert the disc and click "OK."
Read more: How to Download Hindi Fonts to Microsoft Office Word ' eHow.com http://www.ehow.com/how_6306649_download-fonts-microsoft-office-word.html#ixzz12qrgA6Vb
2.
If this isn't the word Gujarati: ગુજરાતી, in Gujarati then your computer probably doesn't have a Gujarati Unicode font installed and you will have problems reading the Gujarati section of this site.
Following are instructions for getting Gujarati Unicode to display properly on various computer operating systems.
Microsoft Windows Microsoft Office 2000 and Microsoft Office XP If you have a copy of Microsoft Office 2000 or Microsoft Office XP, or Microsoft Publisher 2002, and Gujarati is not displaying properly then you should install the Arial Unicode MS font which is distributed by Microsoft with these products.
If you are unsure how to install Arial Unicode MS from CD then please consult the Microsoft Help and Support website - try searching for "Arial Unicode MS".
Windows 98, Windows ME, Windows NT 4.0 and Windows 2000 Windows 98, Windows ME, Windows NT 4.0 and Windows 2000 are not distributed with Arial Unicode MS so you will need to install an alternative Gujarati font.
You can download the following free, open source Gujarati fonts from the Indictrans Project:
Padmaa Medium, Padmaa Bold
Once you have downloaded the font file you can install using the font utility in the Control Panel, alternatively just copy the .ttf files into your \windows\fonts\ directory. There are more detailed instructions on our installing fonts page.
Oct 19, 2010 | Microsoft Windows XP Professional SP3 Full...
Please give me Rupees symbol
Is this the symbol what your after (below) download the font here Copy the file to C:\Windows\Fonts directory.(for Windows XP users)
Right-click the file and choose “Install”. (for Windows 7/Vista users)
Use the ~ key to inset the font into documents. be aware however this wont work in instant messages or email, as the font is not part of unicode character set. 62adf40.png
Sep 01, 2010 | Computers & Internet
Hw to copy my Your Handwriting fonts from Windows 98 to XP
i had the same proble mabe the file is crupted or bad sector try to use ur 98 os cd to fix it
Aug 05, 2009 | Databecker DATA BECKER 1000 Essential...
Computers & Internet Logo
631 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
