Question about Sony KP-51HW40 51" Rear Projection Television
Hue wont align and causes ghosting
I press the Flash focus button but it doesnt do anything to help never aligns just ghosts
  • boomerboy Feb 16, 2009
    I have the same convergence problem but my Sony model # is KP-46S25.
    Can you provide the kit number i need? Thanks so much
  • Sony Master
  • 8,617 Answers
You need to replace the convergence ICs and pico fuses. The KP46WT510 convergence repair kit at the following link works for your model as well and the kit comes with instructions on how to do the repair. Its listed under the convergence repair kit category.
http://servicemanuals.vstore.ca/
Posted on Feb 15, 2009
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
The picture is double pictured with what appears to be a ghost
projection sets on occation need to be re-alligned. check your owners manual if you have one and re-align your lamps to the test screen that is displayed when you press 'menu' from your remote or from the front of the tv. This should fix alot of it and you may find the color adjustments may need adjusting after re-aligning your lamps. hope this helps. I had one and that sounds like the 'ghost' images I had till I did this.
Aug 11, 2009 | Toshiba 55H70 55" Rear Projection...
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Ghosting
This sound like a convergence problem and maybe another problem for the pink symptom. I would not suggest to do it yourself on this one because after the IC's are put in and sometimes a resistor or two there is also a very extensive alignment that could occur. Just off the cuff have you pressed the magic focus button on the front? If magic focus don't fix then the convergence is bad . Suggest a good tv repairman.
Dec 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Half the screen has ghost image (not focused)
Replace the convergence ICs. They are located on a large aluminum heat sink with STK numbers stamped on them. They cost about 10.00 each. They have to be soldered in. Let me know if you need anything further.
Aug 23, 2007 | Sony KP-53S65 53" Rear Projection...
Convergence problem????
Yes Its the stk Packs,They are usally 18
Jul 23, 2007 | Toshiba 42H82 42" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
