Question about LG Flatron F700P 17" CRT Monitor
No pitcure display only horizontal line appears
Not getting display, just a horizontal line appears. How to fix this?
Thanks & regards,
Shakuntala
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The horizontal line indicates failure in the vertical section. Almost always, this would be a faulty vertical IC. In some instances, it can be or may include the diode, limiting resistor and filter capacitor coming from the FBT providing the Vertical B+ ~ 28VDC. You would need a DVM/VOM to check for the presence/absence of voltage.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
I have a Nikon D100 with a Nikon AF Nikkor 24-85mm 1:2.8-4 D lens or a Nikon AF-S Nikkor ED 7-300mm 1:4-5.6G VR lens. I'm on vacation in Hawaii and am troubled by an error that appeared today. The...
Hi
i know what exactly the problem, but if your unit is under warranty go to Nikon service center the problem is in hardware and only Nikon can fix that..and only nikon have parts for that!
Thanks! Likha
Sep 23, 2008 | Nikon Cameras
Voyage 200 pixel line problem
GUEST... thank you very much.. works fine with my voyage ;)
Mar 31, 2012 | Texas Instruments Voyage 200 Calculator
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Sep 15, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Horizontal lines on front display
The screen has cracked. If this isn't a physical damage andthe phone is under warranty; you must take the phone to the nearest nokia care and avail the warranty.
regards
Sandeep
Oct 19, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Horizontal lines on ASUS laptop screen
HI friend
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is Motherboard problem Please contact Your nearest service centre for Service.
Jul 15, 2009 | ASUS VW222U Monitor
Fine horizontal lines on the screen
this may be due to fault in your display panel, check it by some hardware professional nearest to you
Oct 03, 2008 | Compaq Presario M2000 Notebook
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
xfr.
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
LG Flatron F700P 17" CRT Monitor Logo
378 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
