Question about Canon EOS 30D 8.2MP Digital SLR Camera Digital Camera with Sigma 28-70mm f/2.8-4 DG AF Lens & Sigma 70-300mm f/4-5
Err 99 appears on lcd after every 5 clicks in canon eos 30D
I am a digital camera repairer from mumbai,i wants to know why err 99 appears on LCD screen after every 5 photographs being clicked.after that camera hangs completely i have to remove the battery and reinsert it to get started.i have disassembled the whole camera and reassembled it but i didn't found anything unusual with mirror box assembly or any other mechanical parts could you guide me about this in detail.
  • 1,305 Answers
The lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera. Let me know how it works for you!
Posted on May 14, 2009
Error 99 ?
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 14, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera will come on but the lcd wont when i try to take a pic it flashes a busy signal in the veiwfinder
I hope that helps.
Jan 24, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera has no display, appears to be locked up, shows busy through veiw finder, otherwise focus ok but no picture taken. Battery and SD card ok.
I hope that helps.
Nov 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error busy canon eos 1000
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Sep 20, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I have a new Rebel xs kit, and after 20 shots, I got the err 99. I did all the above, that is from cleaning contacts to everything possible procedure mentioned in this forum. There are few things that I...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
I hope that helps.
Aug 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
How can I solve an error 99 problem in my Canon Rebel xs
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
Error 99 on 30D Canon
Had this problem before and i found this guide online
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Canon EOS 30D 8.2MP Digital SLR Camera Digital Camera with Sigma 28-70mm f/2.8-4 DG AF Lens & Sigma 70-300mm f/4-5 Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
