Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer lint throughout the house
Lint is coming from the dryer and settling throughout the house. She cleans the vent with every use, but it does not help.
  • 1 more comment
  • greg_rinehar Feb 15, 2009
    I inspected the vent pipe and it is fine, no clog or hole. This is a fairly new dryer, I know nothing about the felt.
  • Anonymous May 04, 2009
    I have the same problem, dryer lint in my rooms upstairs, especially in the bathroom directly above the basement laundry room. The dryer is vented (gas) outside but husband has a bunch of pipes taped together with duck tape that looks loose. Dryer lint is all over the outside of the tape and I suspect it's the leak. He says it is just an old dryer and they all leak lint. I am mostly concerned about being tired all the time and feeling disoriented from time to time - that this dryer could be leaking more than lint when I run it (into the house); carbon monoxide? The lint is the color of my red towels!
  • Dan Webster
    Dan Webster May 11, 2010
    Have you inspected the drum felt? Have you a hole in the vent pipe?
    Is your outside vent clear? Sometimes snow blocks the pipe.
  • Maytag Master
  • 8,220 Answers
The filter must be cleaned every load
Posted on Feb 16, 2009
    Genius:
  • 1,122 Answers
I think the dryer vent hose on the back is clogged or has come off,check that and let me know-mike
Posted on Feb 15, 2009
  • MIKE major Feb 17, 2009
    very unfair rating,please retract it,
A curious question concerning the lint trap. When I took the back off the dryer and took off the section that houses the lint trap I found lint half way down the in this section along with what appears to...
I am a furnace repair guy by trade, but as far as I know there shouldn't be anything in the lint trap section, are you sure its insulation and not lint?
If you had lint going that far down the trap, you may have lint plugging up your line going out the house. If you have the flexible pipe with the rings on it going out the house. I would look into the cleaning out the vent line.
One test you can do yourself, run your dryer find the vent on the outside of the house and feel the air coming out, if its hesistant or slow coming out, your vent might plugged up. If you have lint hanging from the vent outside or on the ground. Definately look into getting your vent cleaned out.
Aug 28, 2013 | Kenmore Dryers
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Four Screws holding the exhaust pipe that the hose connects to on the lower back of the dryer. Remove those screws and pull the pipe out - It has a rubber gromet on the inside end that should fit onto the opening on the inside of the dryer. May need a flashlight to see inside while aligning it when putting it back in.
Feb 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer lint throughout thr house
lint throughtout hte home is a sign tha there is a tear / or a disconnect of the dryer vent. check your venting
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
112 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
