Question about AEG Washing Machines
Door seal damaged on Lavamat 830
The door seal has been torn with a button catching so machine is leaking. is it possible to repair or replace seal
    President:
  • 842 Answers
Yes, you can replace the seal. See my article http://www.fixya.com/support/t1543617-door_seal which should give the guidance that you need
Posted on Feb 15, 2009
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
Water leaking from door
This video will show you how to change a door seal on this Bosch front loader washing machine to stop leak
we have all bosch repairs in our channel
You can get seals on eBay
Aug 29, 2009 | Bosch Washing Machines
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Jul 06, 2009 | Washing Machines
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Frotnt door seal ghw9150
why ? is it torn and leaking or just mildew? if not torn cleaning best bet with chlorine bleach and water.if you still want to change it remove spring front front edge pull seal back toward drum on back section big clamping band remove band pull seal off and reinstall reverse order can be a dog if not experienced good luck
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WASHING MACHINE DOOR SEAL REPLACEMENT
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Sep 17, 2007 | AEG Lavamat W1050 Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
102 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
