Question about Philips Televison & Video
No color output from philips 751/171 dvd player
Running R.C.A. jacks 3 wire to RF modulator ( converting to coax ) into TV but not getting any color picture. only black/white. Audio is fine. Philips mod 751/171 DVD player.
  • 40 Answers
Hello.
The RF modulator sends on a certain frequernzy(Channel) usally around channel 36 on UHF. If there is a adjustmen screw on it try and turn it util the picture disapears and then search for it on the tv again just to make sure nothing else is interfearing on the channel the RF modulator is sending on now.
An alternative if there is no adjustment on your RF modulator would be to change the frequenzy on your VCR or other devices attached to your TV that might send on the same frequenzy as your RF modulator.
Regards..
/Tech5508
Posted on Feb 15, 2009
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
Mar 22, 2015 | RCA Televison & Video
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Jan 02, 2015 | Televison & Video
I have a rf modulator i dont no where any thing goes i tryed i just dont understand it i just brought a dvd and vhs to gether
alot of DVD/VHS combos have a built in RF modulator. Look for a coax (screw threads) output on the unit and it should be labeld either DVD/VHS OUT or just VHS OUT. If it does not have a combo out then you will need to use the seperate RF modulator.
Your combo unit should have a set of yellow red and white jacks that are labeled DVD & VHS OUT. Connect these yellow red and white to the yellow red and white on your RF modulator, then connect the coax (screw threads) out on the RF modulator to the coax jack on the back of your TV. There is also typically a swich for channel 3 or 4 on the RF Modulator, make sure you TV is on which ever channel you have that switch set to. If your RF modulator has a power light on it, it will usually not come on until your DVD/VHS is sending a signal through it and it is connected properly.
If you have an antenna or cable box, your RF moudulator should have an Antenna or Cable input jack on it that you can use.
May 05, 2011 | Magnavox DV220MW9 DVD Player VCR
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Can not make the instalation betwen my tv and my dvd player
Most DVD players today have only RCA jacks for video and audio outputs, and don't have RF (channel 3 or 4) outputs. If your TV doesn't have AV input jacks (either too old or just not supplied on your model) you can't connect the DVD player directly. You'll need to get an RF converter to make the connection.
An RF converter costs about $15 and you'll find them where you can buy TVs. The converter takes the video and audio signals from the DVD player and creates a channel 3 or 4 output signal to your TV. If you don't have the cables already, make sure to get them too. You need a "dubbing cable" (RCA plugs on the ends, usually color-coded red, white and yellow) to connect the DVD player to the converter input jacks and an RF cable with "F connectors" on the ends for the output to the TV. Often the dubbing cable comes with a new DVD player, and the RF cable with the RF converter.
If this takes care of your connection troubles, please take a moment to give my solution a good rating. If I've missed something and can be of more help, please post a followup comment.
Mar 31, 2009 | Symphonic ST4819 19" TV
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Jan 12, 2008 | Televison & Video
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
259 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
