Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow water not spinning
When i on the machine, the sound is not as loud as usual, then i realise the water is not spinning. suction seems to be ok, it still pick up hair, but water is not spinning to cleanse it. :( i pressed reset button, wash the separator, didn't help. any idea? thanks in advance!
  • Rainbow Expert
  • 324 Answers
All Rainbows - remove the hose and turn it on without the hose plugged in - if works better - hose is clogged
If it works bad even with the hose out:
E-series Rainbow - take HEPA filter cartridge and try then. If helps - you need new HEPA (you can get it here)
SE Rainbow vacuums - remove exhaust cap
and you may find a dirty sponge in there - just remove it and it may help.
If none of that made any difference - you may need it to be checked. If you do not mind shipping - our info is HERE
Posted on Mar 12, 2009
Why does (it) have very poor suction?
The filter can be clogged but look clean. Most models have two filters. Replace them both every few years.
Jan 30, 2016 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
Rainbow Vacuum, about 5 yrs old (bought new, no issues prior) - my 6yr old tipped it on it's side while water was in basin. Now when I turn the power on, it makes a very loud sound in the motor and you can...
Although a wet/dry vacuum, it cannot tolerate water in the motor. Water will cause the motor to short out, which will cause the motor to act/sound like yours does now, if it continues working at all.
To prevent additional problems, the vacuum needs to be taken to an authorized Rexair dealer for cleaning and repair. Expect at the very least to pay for a new motor and installation.
Problems like this are why I don't care for any wet/dry vacuums, especially spendy ones.
Oh, you should definitely discontinue use, and don't attempt repairs on your own. Special tools are needed, and if bolts and screw are rusted, breakage may result.
Feb 27, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum loss of suction
If it is not the Hepa filter, you can check it by removing it running machine and seeing if there is a difference. It is always good to have your unit serviced about every 5 - 8 years or so.
Mar 29, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Suction not working in upright
Hi.
You will have A blockage in either the wand or hose, completely remove them from machine the hose unclips at the bottom back of machine,
Now switch machine on with this removed if machine sounds ok then remove the blockage from hose or wand.
If machine still poor suction & noisey with hose & wand removed check the (U) shaped inspection port for blockages.
Let me know how you get on.
http://dysonmanuals.llc.nu/index.htm
May 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loud rainbow and water leaking
If pieces are missing or broken I would try and replace the piece. You can usually get these items cheap on Ebay.
Apr 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Low suction
Is the water seal in place or missing? Another cause would be a bad motor, running at a slower speed will mean low suction. If it is a motor, then you would have to replace it. Is the suction low at machine without the hose, if it is ok then may be a clog in the hose.
Feb 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
It sounds fine but it is sucking very little
If the suction at the port that the hose hooks into has low suction, then most likely you have a problem with the motor. Some of these Rainbow motors sound ok running, but are running at a slower speed, thus reducing the suction and replacing the motor is the solution.
Dec 24, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
164 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
