Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Lan connection & any computer internet connection
Lan setting and internet cionnection any computer
  • 1,602 Answers
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Jun 11, 2011 | Computers & Internet
I have an Acer Aspire 5315 laptop and I can't get on the internet. It shows an internet connection but won't connect. I restored the computer to the factory settings and lost everything. Still can't get...
Open the internet explorer
Click on Tools tab on upper right side corner
Then click on Internet Options
Then click on Connections tab
Then click on LAN Settings
Make sure nothing is checked over there.
Then click OK OK and then try to go online.
Feb 14, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
Hi, u just by a new asus k50ip with preinstaled W7home premium,my cionnection is good,25mbps messured,but i still cant use skype for calls/other side dont hear me properly{skyoe is saying that connection...
check it for viruses and malware. do all windows updates
try to plug into lan with cable to make skype calls see if that is any better. wifi is sometimes not as good
Jul 14, 2017 | Computers & Internet
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
CANNOT CIONNECT TO WIRELESS ORANGE NETWORK
Is this a new laptop, or was it working and just stoped.. When it says internet connection is disconnected, did you try setting up the wireless settings, or just turn it on and it didn't work. If its the latter, right click on the network settings "properties" and see if it's showing. If not then look on tht same page and select "create a new connection". It will set up our laptop, just follow the directions
You may be asked to connect a wired connection to yyour router, until it gets the information it needs, at some point it will ask you to remove the wire, that should get u going, ty
Jan 22, 2009 | Acer Aspire 4315 Notebook
Wireles connection shows connected but cannot open any web page
check your internet settings
for Internet Explorer
1. open browser, click tools menu the select "Internet Options"
2. in Internet Options select "Connections" tab
3. at Connections, click "LAN Settings"
4. at LAN settings "Automatically detect settings" should be mark check
5. click OK to save settings, close Internet Explorer Browser and open it again.
for Firefox Browser
1 open browser click "Options" menu
2. at Options, select "Advance" then select "Network" the click "Settings"
3 Connection Settings, select "Direct Connection" if your computer directly connected to Internet provider otherwise select "Auto Detect Proxy Settings" if your using a Router.
4. click OK to save changes, close youi browser and open it again.
Hope this will help you.
Nov 25, 2008 | NetGear WGT624 Wireless Router
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
