Question about Rainbow 75th Anniversary Canister Vacuum
Rainbow vacuum-water not spinning
When i on my rainbow vacuum, the water is not spinning. suction seems to be still working, still picking up things, but the water doesn't move, the air is merely blowing on the water surface....
  • Rainbow Expert
  • 324 Answers
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Posted on Mar 21, 2009
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
My Rainbow has no suction
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
Thank you,
Ralph
Jan 27, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum loss of suction
If it is not the Hepa filter, you can check it by removing it running machine and seeing if there is a difference. It is always good to have your unit serviced about every 5 - 8 years or so.
Mar 29, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow water not spinning
All Rainbows - remove the hose and turn it on without the hose plugged in - if works better - hose is clogged
If it works bad even with the hose out:
E-series Rainbow - take HEPA filter cartridge and try then. If helps - you need new HEPA (you can get it here)
SE Rainbow vacuums - remove exhaust cap
and you may find a dirty sponge in there - just remove it and it may help.
If none of that made any difference - you may need it to be checked. If you do not mind shipping - our info is HERE
Feb 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Suction paower
First thing is to check all your hoses, and filters. Filters rob your vacuum of air flow which equals power.. I don't think that you have a clog so much as I am inclined to think that you have dirty filters. In a wet vac, you can rinse your filters out, but they will eventually need replaced. It's a good idea to have an extra filter around for such an instance.
Jan 19, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Weak suction on rainbow se vacuum
Check for clogs in the nozzle air passages (remove bottom plate)
Check for clogs in the wand
Check for clogs in the hose (trow in a pebble or a penny and see if it comes out the other end)
Make sure separator is clean.
Remove exhaust cap (sometimes there is a sponge in the cap that gets disty and does not let the air pass through).Have in mind that it will not pick up well if the suction and the belt is good but brush roll bristles are worn and too short.
Good Luck,
Rocky
Dec 21, 2008 | Rainbow 75th Anniversary Canister Vacuum
Cant get rainbow shampooer to work
use the suction port for the vac hose
the water hose hooks to your kitchen faucet
Nov 11, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Older Rainbow Noisey
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
310 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
