Question about Fuji FinePix A101 Digital Camera
The power supply get drops
When I turn on the power suddenly the light on and then turn out.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A few ideas that you can consider/try:
  • make sure the batteries are fresh/fully charged;
  • clean the battery terminals of the camera;
  • in some instances, it may be needed that these terminals be scrapped/scratched to remove corrosion/oxidation and expose fresh metal;
  • at times, it may even require that these contacts be stretched/bended so as they offer stronger pressure to the batteries.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
Modle number tc-p42x5
The sudden drop in operating voltage may have caused the power supply to fail.
Mar 05, 2014 | Panasonic VIERA Televison & Video
Laptop lost battery back-up suddenly.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 06, 2012 | Acer Aspire 5810T-8060 Notebook
Turns on immediately turns off
check for shorted component parts at power supply board like bridge type diode and FET transistor. if those are good, disconnect the connectors that supply going to inverter board and then turn on the tv unit if the light indicator at front panel stay and 24v supply doesn't drop which mean the inverter board was the problem of suddenly turn off.
Sep 01, 2012 | Samsung LN19B650 18.5 in. HDTV LCD TV
Why does my vizio lcd 47 in tv just suddenly turn off. I will be watching tv and suddenly it just goes off. The vizio power light then blinks steady for about 1 min and then the tv starts up again, as if...
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it by using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
I hope this solution helps you to fix your problem.Thank you and good luck.
Jun 13, 2011 | Vizio VO47L 47 in. LCD TV
No power. the t.v. suddenly turn off
Problem sounds like the power supply pcb if the tv is totally dead with no standby light. However, first check that the main plug fuse is not faulty by replacing it ro checking with a multimeter
Mar 17, 2010 | LG Televison & Video
Playing my ps3 and suddenly it turned off and wont turn back on.
Hi. this is a basic power supply issue. it has failed. you will need to replace the internal power board(supply). this will fix your issues.
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Fuji FinePix A101 Digital Camera Logo
52 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Tony
Are you a Fuji Camera Expert? Answer questions, earn points and help others
