Question about Microsoft Visual Basic 6.0 for PC
Putting a slide show
How can i put a slide show in a vb form? I'm using vb 6.0
Remove
Posted on Feb 15, 2009
How to connect excel file with html form .
You will need a backend program in VB or Java to connect your form to an Excel File. Vb beign the first reccommendation
Mar 17, 2010 | Microsoft Office Standard for PC
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
How to create crystal report in asp.net with vb script code
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
Apr 15, 2009 | Computers & Internet
Change password
Take a look to these sources:
www.daniweb.com/forums/thread147578.html
http://www.xtremevbtalk.com/showthread.php?t=66397
www.dreamincode.net/forums/showtopic50989.htm
http://bytes.com/groups/net-vb/370700-login-name-change-password-form-vb-net
www.bigresource.com/VB-Change-password-character-DFHreV6rQq.html
I hope they could help you Good luck
Mar 04, 2009 | Computers & Internet
Access-VB
Use this line below:
Private Sub CommandButton_Click()
Dim NumericValue as Integer
Dim StringValue as String
NumericValue = CInt(TextField1)
StringValue = TextField2
DoCmd.RunSQL "INSERT INTO NameOfTable ( [FieldName1], [FieldName2]) VALUES (" & NumericValue & " , '" & StringValue & "');"
EndSub
I Hope this work for you... God Bless
Jul 16, 2008 | Microsoft Office Access 2003 (077-02871)...
Pls hepl me wit Excel VB integration
you can use a OLE object that is available in VB as standard object. Drag the tools to your form that your creating and it will ask for create or link existing object. so now browse to the excel sheet and embed it into the VB form or use run time for manuplating the cells and other info in excel.
Mar 25, 2008 | Computers & Internet
How i can change forms backcolor through coding in vb.net
ok you have 3 choices
assuming your form name is main.
main.backcolor = color.blue
or
this.backcolor = color.blue
or
me.backcolor = color.blue
you can type your form name followed by the . to get all options for changing it peoperties,
or you can type this. refering to the form your are currently in, this has the effect just as the form name,
If you are programming on the formitself you can use
me. same effect as the form name..
Jan 18, 2008 | Computers & Internet
View Reports
Hi, There a couple of different way you could do this and I have put two lots of VB code below that you can modify and use. Firstly you create the Combobox list by choosing the option that you will type the values yourself, you then type in all your report names on each line. After that you can then go to the VB code editor and paste my code in and modify it by changing my report names, (Customers) etc to your report names. Make sure you choose the Combobox and the On_Click option in the VB editor to paste the code into.  I like the first method better which checks the value of the Combobox and then opens the corrosponding report in the maximised form. The second method does the value check before running an assigned macro to open each report. With this you must first assign macros to each report in Access.  Remember each of these bits of code must be placed between the "Private Sub" heading and the "End Sub" ending, and change the "Combo23" name to reflect your combobox too. If you need a hand just email me.
First Method
If Combo23.Value = "Customers" Then
    DoCmd.OpenReport "Customers", acViewPreview, acWindowNormal
    DoCmd.Maximize
ElseIf Combo23.Value = "Customers 1" Then
    DoCmd.OpenReport "Customers1", acViewPreview, acWindowNormal
    DoCmd.Maximize
ElseIf Combo23.Value = "Customers 2" Then
    DoCmd.OpenReport "Customers2", acViewPreview, acWindowNormal
    DoCmd.Maximize
End If
Second Method
   DoCmd.RunMacro "Macro1"
   DoCmd.Maximize
    DoCmd.RunMacro "Macro2"
    DoCmd.Maximize
    DoCmd.RunMacro "Macro3"
    DoCmd.Maximize
End If
Oct 28, 2007 | Computers & Internet
Ms access
Stored Procedures don't exist in MS Access. You do have the following options though. Queries, which are just select or action queries. VB Code, which you can write using Query Objects as if you were writing a Visual Basic application. These can be Functions or Subroutines. In these, you would use the standard programming techniques with while and for loops, etc.
You can create complex situations combining the two of these. A function in the VB code area can accept through parameters, the single values (line by line, record by record) in a query and act on them and manipulate the values.
For example: create a query that does a select phone from address. Create a function in vb called public function StripDashesInPhone(Phone as string) which then uses VB coding to strip dashes from each phone value passed in. To make it all work, in the query on one of the field columns put "NewPhone: StripDashesInPhone([Phone])" and for every record processed in the query, the function is called with the [Phone] field value passed in to the function and the action is processed and returned.
Other than writing a function that is activated by a form button click, which opens the current db and opens a table and process it, just like in VB, this is about as close to cursors and oracle procedures as you get.
I wish it was more, but ...
Oct 09, 2007 | Microsoft Office Standard for PC
Microsoft Visual Basic 6.0 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
