Question about Sony GR-6.1m Gravity Mono Channel MOSFET High Power Car Amplifier (1000 Watts Max Power) Car Audio Amplifier
I need to know what kind of fuse my amp takes...
I have a gravity audio gr 6.1 m 1000 watt monoblock car amplifier...and i blew a fuse..but i dont have a box to tell what kind of fuse it is....i went to the website and it said a 25x2 amp fuse....but i have know clue what that means..i dont know how many amps it calls for..
  • Perry Babin May 11, 2010
    They are probably ATC/ATO fuses. The dimensions of the end of an ATO/ATC fuse are 0.2" x 0.75". You can measure yours to determine if they're the same.
  • 55 Answers
IT MAY MEAN THAT IT TAKES (2) 25 AMP FUSES
IF YOU HAVE THEM OUT SEE IF IT SAYS WHAT THEY ARE OR OPEN IT UP IT MAY SAY IT ON THE BOARD OR THE FUSE HOLDER OR LOOK @ THE SPECS ON THE AMP SEE WHAT THE TOTAL CURRENT IS YOU CAN ALWAYS START WITH A SMALLER AMPAGE LIKE 10 -20 AMP FUSE ALWAYS GO SMALLER
Posted on Feb 21, 2009
Audio speakers
Have you installed Kicker capacitors? With the extra power you have you will need them to help with the load.
Jan 28, 2014 | MA Audio Car Audio & Video
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
No problem just need advice
if you use for bass need to adjust to a 120Hz in the amp & eq
Apr 26, 2010 | Performance Teknique ICBM-772 Car Audio...
The amp just kicked off last night and wount come back on. power light is on and cables are connected. fuses look good too. did i kill it?
yeap you killed it.....same thing happened to me with a 800 watt pioneer monoblock amp. took it apart to find that a copper ribbon had been totally melted on the board.
Oct 07, 2009 | MTX 3002 Car Audio Amplifier
What size fuse does the XM 7676W Car Audio Amplifier take? mine blew and i got the amp from a friend so i dont know?
Do not use anything bigger than a 10amp fuse. Cheaper to replace a fuse than an amp. 10 amp is usually the standard.
Apr 25, 2009 | Koiiler XM-7676W Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I dont know waths the amp for the two fuse on my Legacy II LA890
On your normal mid range amp it uses 20 amps, but on your up scales amps they use 30 amps
Dec 15, 2008 | Legacy Audio American Legacy II LA890 Car...
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Car Audio & Video Logo
354 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
