Question about RCA D52W19 52" Rear Projection Television
Rca d52w19 chassis itc222
My little glass fuse busted on the board the numbers around it are bp410 , cp40, rp400 what fuse do I replace it with? Couldn't read anything on it. Would Radio Shack carry it?
  • 5 more comments
  • karen998 Feb 16, 2009
    We did take it to Radio Shack. They were not helpfull at all..Would any fuse work?
  • Anonymous Feb 16, 2009
    I put the 5amp fuse in and it turns on without blowing but now the picture is bowed, and the colors are not together.. try to set the convergence and it will not move on either colors.
    used a 5 amp fuse and it will turn on now and the fuse has not broke. But now the screen is bowed at the bottom and the colors are messed up.. I have tried to set the convergence but the + will not move on either way..
    Where could I get that part?
    Thanks I got the part ordered I'll let you know how it goes
  • karen998 Feb 24, 2009
    okay I found the transistor that is the problem but I can't find the part number on it. It's has three legs and two of them are burnt into. How could it find this part number?
    Sergeant:
  • 227 Answers
The fuse rating should be on the metal side of the metal ends of the glass fuse. Very hard to read amps and rating, may need a jewelers lupe. Or take the remains to Radio Shack.
Posted on Feb 15, 2009
  • 1 more comment
  • Mike Schmidt
    Mike Schmidt Feb 16, 2009
    The numbers around it are not helpful. Usually where the fuse is connected or plugged in there will be written on the board stating the amp such as 2amp, 3amp. Depending on the circuit it is in I would try a 4amp and see if it holds. I would not go higher than 5amp. If it blows you have other issues. Let me know how you do.
  • Mike Schmidt
    That's a start, you probably have a bad horizontal output transistor. It would be located around the high voltage transformer. It will be on a heat sink (flat transistor on a flat metal) usually has three leads and the board will have Horizout possibly on the board. There is a number on the transistor like S2055N you have to put it back in the exact way it came out, if you have soldering capabilities.
  • Mike Schmidt
Keeps shuting off.
Hello bondaddy60, I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 09, 2009 | RCA D52W19 52" Rear Projection Television
COMES ON BUT GOES BACK OFF RCA D-52W19 REAR PROJECTION
Hello ,
I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
I hope this helps,
Shuttle83
May 24, 2009 | RCA D52W19 52" Rear Projection Television
My rca d52w19 will blink, but not come on.
Hello ,
I hope this helps,
Shuttle83
MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 17, 2009 | RCA D52W19 52" Rear Projection Television
RCA HDTV chassis # ITC222 will not come on.
most likely the Flyback 259296 and CP150 you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Nov 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Part Number
the part number is 259307 for the ITC222 chassis its over 300.00 for the board although you can get one at the following link for about half that price. They dont list them, But they have them you just have to leave a email this is what the small signal board looks like. http://servicemanuals.vstore.ca/444d206.jpg
Jul 31, 2008 | RCA D52W19 52" Rear Projection Television
You need to replace the flyback its flyback 259296 and you can get a new replacement for 47.99 at the following link.
Jun 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
That is an ITC222 chassis and one of the more dependable RCA units built. The "F" connector is the part you're referring to and it's not something that carries a specific part number for that unit. In the shop here we simply buy them by the box and the tuner will have to be removed to install a new connector. The new one will be soldered to the chassis of the tuner and less likely to break in the future. Not something you probably want to do yourself, but at least you'll know what to ask the shop when you're calling around for estimates.
Nov 05, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
232 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
