Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Whirlpool WRX38R (top freezer) Water drips from Frig. roof
In only the last month, water drips irregularly from the openings towards the front of the refigerator roof, below the freezer compartment. Has to be absorbed by leaving rolled-up towel in upper shelves of the frig.
Temperatures in freezer and frig. are normal for their purpose.
However, at no time since purchase (Dec 2001) has water collected in the evaporation tray at the rear of the refrigerator: it has been dry at each inspection.
  • Nicesuit
    Nicesuit May 11, 2010
    could either be a door seal that is tired or (if its a frost free) the drain hole in the rear of the freezer could be blocked/frozen up.
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
aasc
  • 1606 Answers
SOURCE: OUR TOP MOUNT WHIRLPOOL FRIG IS DRIPPING WATER
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Sep 26, 2009
Testimonial: "THANK YOU VERY MUCH. YOUR SOLUTION WAS SPOT ON. I USED ONE OF THOSE COPPER GROUNDING WIRES TO PUT IN THE DRAIN HOLE AND WRAPPED END AROUND BLACK TUBE."
aasc
  • 1606 Answers
SOURCE: Refrigerator is producing water which seems to
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 26, 2010
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water
Look at your door gaskets. If they ain't kosher then excessive humidity will build into the frig.
Jan 02, 2009 | Frigidaire GLRT188WD Top Freezer...
Slow dripping water from top freezer into the main fridge
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Oct 23, 2008 | Whirlpool Refrigerators
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
