Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Acomdata 250 external hard drive
I have an Acomdata PHD250UHE-54-LS external hard drive. I bought it in August and it has worked great however I now got the message telling me that I must format the drive before I can use it.
It doesn't show any files.
I do get a G: prompt.
The unit is humming as normal.
The light is blue (normal).
How do I get my files off of the drive and what should I do?
SOURCE: Flashing Red Light
the drive is just connecting to your pc. now if it always stayed red, you'd have a problem.
Posted on Jul 27, 2008
SOURCE: acomdata hard drive doesnt show up on my computer
I have the 250 GB Acomdata drive. Had the exact same problem--computer would not recognize drive; blue light on drive lit and drive making a slight whirring/clicking noise. I read somewhere that some people that have had this problem have found the problem is with the USB interface between the drive and case, NOT with the drive itself. I took the drive out of its case and installed it in a desktop computer and was able to get all of the data off of the drive.
Posted on Dec 31, 2008
Crankstart
  • 696 Answers
SOURCE: flashing red/blue acomdata 1 terrabyte external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
PC Commando
  • 142 Answers
SOURCE: red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
Posted on Sep 17, 2009
Geekinator
  • 183 Answers
SOURCE: External Hard Drive not showing on My Computer? [URGENT]
Hello there Mansoor.
First, I have to commend you on how clear and extremely well articulated your problem is presented. You give every detail necessary to grasp your current situation. Good job! I can also clearly see you're at least a fairly proficient user. I only wish I'd reviewed your question before now, so I could have replied sooner. That notwithstanding, here's my GEEK-steer ...
Good job testing the drive against other "known good" systems. Because (as you probably already know) based on that, it's a virtual certainty it's the drive itself that's the source of the problem (UNLESS you used the same USB cable in all tests ... rule that out by using a "known good" cable). Its trouble could be caused by any number things [e.g., deleted partition, virus related, "sector" (file/folder structure related) errors, etc.]. At this point you've utilized all the tools that Windows avails you to work this problem (e.g., you obviously can't perform a Windows "chkdsk" on it unless there's an assigned and known driver letter, "Disk Managment" was no help, etc.). We therefore need additional software tools in order to proceed further.
Per the manufacturer's webpage, "Acomdata does not have any Windows XP, Windows Vista or Mac OS drivers because all products use the built-in driver support already supplied by the associated Operating System". Therefore, they design all their devices to be supported by Windows' database of generic drivers. However, here's their offered driver package for "All Platforms". It's a long-shot, but it couldn't hurt to start by giving this driver a try (you can always "Roll back driver" from within "Device Manager" if necessary).
== CAPTURE AN IMAGE BACKUP ==
If, as you state, data recovery is of the utmost importance, then I would strongly advise your very first objective to be (if at all possible) creating an image of the problem drive, then backup that image onto another drive. I would do that FIRST to lock in it's current state as an insurance policy, BEFORE I ran any testing/diagnostics, or attempted any alternate means of data recovery. Keep that image intact throughout this process until resolution. There are several disk image "Backup Tools" (e.g., "DriveImageXML", "Acronis True Image", etc.) in "Hiren's Boot CD" you can use to accomplish this.
== BREAK OUT THE TOOLBOX ==
Refer here for complete list of its available tools. There are far too many to cover in any detail here. Particularly when the nature of your problem is yet known, as each may, or may not be THE one for the job. However, you can simply Google each to obtain background and usage instructions. Also, tools reside in either the DOS or mini-Windows boot portions of the CD, as some are DOS executable and some Windows. You may have to venture into both until you find the tool that works for you. I know there's a lot in that puppy, but that is intentional because it's a good thing ... affords wide range of choices/options.
== HOW-TO CREATE 'HIREN'S BOOT CD' ==
  1. Download "Hiren's Boot CD".
  2. Extract/unpack/unzip/decompress (<-choose your term, they all mean the same thing) the .ISO disk image file ("Hiren's.BootCD.#.ISO") located within the downloaded "Hirens.BootCD.#.zip" archive file (where # = version of Hiren's).
  3. Burn the disk image to a CD using whichever capable disk image burning software (e.g., Nero, Roxio, etc.) you may have. Don't have one? Then download and install the very capable, yet lightweight FREEWARE "imgBurn"
Burn the extracted .ISO image file ("Hiren's.BootCD.#.ISO") to CD using imgBurn:
  1. Insert a blank disk (R/RW) into your disk burning capable CD/DVD drive.
  2. Launch "imgBurn", then select "Write image file to disc".
  3. Browse for and select the "Source" .ISO file above.
  4. Ensure the applicable disk burner drive is selected as "Destination" (you may have more than one).
  5. Click the burn icon.
  6. When burning completes, close "imgBurn".
== RECOVER THE DATA ==
Next I would attempt recovering the data using any number of Hiren's "Recovery Tools" category of tools (e.g., "ProSoft Media Tools", "GetDataBack for NTFS", "TestDisk", "Ontrack Easy Recovery", etc.). Many of these include diagnostics/repair facilities you can use in the course of your recovery efforts.
== RECOVER/FIX THE DRIVE ==
Then once/if you've successfully recovered the drive's data, you can (if applicable) use any number of Hiren's (hard-drive related) "Testing Tools" and "Hard Disk Tools" categories of items in order to fully test/diagnose and hopefully recover the drive to working order.
TIPS:.
  • Be aware that you MAY discover you'll HAVE to perform testing/diagnostics/maintentance related actions on the drive first, just in order to get it into recognizable shape for any of the drive image and/or data recovery related tools to perform. That's OK, 'cause "you gotta do, what you gotta do".
  • "Partition Find and Mount" might be particularly helpful in recognizing, then mounting the drive
I apologize in advance for any logic-sequence or grammatical errors this reply may contain. I culled together a few differing draft stage portions of some "Tips & Tricks" I'm intending to post in the near future.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 09, 2009
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
My acomdata 250 GB freezes and does not allow files to be copied and or moved back to desktop computer or to new files within the 250 external drive
there are three main reasons for a hard drive to freeze
up 1. you have reached the capacity of the drive or 2. the drive heads are worn to the point where the drive can not boot up to the PC , meaning the heads need
to be replaced 3. the interface between the unit and
the PC 2.0 high speed will not work into a 1.0 USB
then you have several minor things that can happen
like the degeneration of the cables that are being used , a quick remedy is to go to my computer
right click on the drive compress the drive to save space then do a clean on that drive and also sometimes the HDD needs to be reformatted .
Jan 15, 2010 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My computer is not recognizing my acomodata external hard drive
Can it work in another port or another computer?Try these option if all fails maybe the device is bad.
Oct 02, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Problems with Acomdata 250 in Leopard
First make sure you follow this guide to uninstall the old version of SecureHD Login you have: http://www.techsupportlive.com/techsupport/MAC/SecureHD_Login/SecureHD_Login_(Uninstall)_User_guide_for_Mac_X.pdf
Then download and install this version of the software: http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=60&nav=0,8
Sep 12, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
ACOMDATA 250
I have the very same problem than the one posted by gyoung826 on Aug 14, 2008. My HD is an Acomdata 160 GB, HybriDrive 2,5
Aug 14, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Bootable drive
check in your bios for setting boot from external device
May 14, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
Apr 08, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
228 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
