Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
