Question about Microsoft Windows Vista Ultimate Edition
About my audio output
I ve bought a cabinet ,which have audio ports on front and rare panels but when i connect the inputs to front panel .it is connecting to some other port ie..back panel .i am using real tek ,i ve reinstalled even the same problem .Always wen i connect it pop up regularly as plugged or unplugged ....even i dont touch it...suggest me soln  please
  • 48 Answers
Ur mobo doesent have this front panel feature.....
connect ur audio devices in the rear ports.
Posted on Feb 15, 2009
How do i get the bluetooth to work on an bmwx 4745
This machine has no Bluetooth:
BMWX-4745
7"
Digital Two DIN In-Dash Widescreen/Touch Screen Monitor, AM/FM Radio, iPod Ready, DVD/CD/MP3/MP4/WMA Player, USB Port/SD Card Slot, Aux, Fully Motorized Front Panel
• Clock Display
• Electronic Audio Control
• High Power Speaker Output
• Rear Audio/Video RCA Input
• Front Aux Input (Audio/Video)
• Video RCA Output
• Front/Rear Preamp Output
• Subwoofer RCA Output
• Rear Camera Input
• Auto Antenna Control
• Auto Handbrake Control
• Full Function Remote Control
Two Din Motorized
Apr 27, 2016 | Computers & Internet
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
BOUGHT NEW FLAT SCREEN NEED HELP HOOKINF UP DVD/VCR
1. Video Output from DVD .. and Video Input in the TV..Used your Yellow cable for Video Output... 2. Audio Output from DVD and Audio Input in DVD (if your TV have a built-in Speaker)
Red & White Cable for Audio Output..
If your DVD has its on Speaker... don't follow the step 2.
if no sound.. please see to it if your speaker of your dvd is connected.. (if not Please connect it)
Aug 19, 2011 | Televison & Video
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
I.ve bought a surround sound set up, which audio output port do i use on the tv cos neither seem to work
This model has two audio outputs. The Monitor out has Video + L and R - L & R are normal stereo and should carry any surround info.
The single RCA Digital audio out must connect to a COAXIAL digital input on the amp.
Dec 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
No sound on left side.
RE-check the audio amp on its own see if this happens with any input device...
Re-check the connections, and be sure your cable wires are all in good condition....and that you have the proper input/output ports correct.
Feb 20, 2009 | Sony KDL-52XBR5 52 in. LCD HDTV
Microsoft Windows Vista Ultimate Edition Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
