Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Thin Twin NIGHTMARE!!!
Washing some towels last night...Not a big load...when this horrid sound tore through the house....I thought it was just off balance since it is IMPOSSIBLE to keep this machine happy...But to my amazement when I opened the washer lid....the whole barrel had fallen away from the metal!!! Can someone please tell me what I need to do here???
Help Please...Damzel in distress!!!
  • 1 more comment
  • Anonymous Mar 23, 2009
    clunking noise..banging noise.. and barrel seems to be in the wrong position
  • kfarme01 Apr 30, 2009
    "through the bottom of the unit" sounds labor intensive. Does that mean the unit has to be pulled out and put on it's back?
  • Rj Ti
    Rj Ti Jun 13, 2017
    Often there is a spring assembly or some form of strut that holds a top loader in position but allows it to dampen the movement of the load.
  • 3 Answers
The tub has simply came off the struts. Best fixed by two people-- one to help hold the tub in position, and one to twist the strut(s) back on-- through the bottom of the unit.
Posted on Feb 25, 2009
Big Thunk when Frigidarie Front Loading washing machine started the final spin cycle, then at the end of the cycle soft screeching sound when drum is moving back and forth, any thoughts? amshap50@gmai
does not sound good. if you can remove a cover on front bottom or on the back you may find a broken shock, or counter weight, either would need replacing before running again
Jan 08, 2012 | Washing Machines
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
Dryer is taking too long to dry, can the element be worn out? whirlpool, thin twin heavy duty, large capacity
If it heats the element is good. Most likely cause is bad ventilation. check the vent on the outside of the house while dryer is running to make sure you are getting plenty of air flow. If you want to check to make sure its working properly general rule is 6 towels should dry in 60 minutes.
Sep 20, 2010 | Whirlpool LTE6234D Top Load Stacked...
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
335 people viewed this question
Dan Webster
Dan Webster
Sal De
