Question edited for spelling and full 'make model (what it is)'.
Please don't type in all CAPS, it is considered SHOUTING and is hard to read.
Question moved from Cellphones category.
1. Back up all data on the internal memory 2. Turn off the device 3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen 4. Quickly release and the resold the power button while continuing to hold the volume down button. 5. Factory data reset appears 6. Use volume down to highlight yes 7. Press power to confirm 8. Volume down again to highlight yes to erase all user data and restore default settings 9. Press power button to reset device
LG E739 hard reset
LG T-mobile myTouch E739 reset
If you can't recall your unlock Pattern:
When the phone is turned off, press and hold the Power/Lock + Volume Down.
After 3 seconds press Back and Menu keys.
WARNING: If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to back up any important data before performing a Hard Reset.
Source: http://www.hard-reset.com/lg-e739-hard-reset.html
First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions. http://www.fixya.com/support/r5705889-puk_code
The C360 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD devices, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
