Question about HP DeskJet 3325 InkJet Printer
My hp deskjet 3550 does not print
When I click the print icon, another window would appear with the heading PRINT TO FILE. I tried to enter the filename of the document I am supposed to print on the space provided for but it still doesn't print. I want to get rid of the PRINT TO FILE window that keeps on popping out everytime I click the print icon and just go directly printing the document.
    President:
  • 2,692 Answers
Unistall the printer(software) then let Windows reinstall the printer, only you have the drivers downloaded(from website link below) and tell it , the computer, where to find them, when asked.
http://h10025.www1.hp.com/ewfrf/wc/product?product=82029&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Feb 15, 2009
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
Printing problem
  1. Open the Printers folder.
    • For Windows XP Select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    • For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon to open Properties.
  3. Click the 'Maintenance' tab and click the 'Print Head Alignment' icon.
  4. The message below is displayed. After confirming the two points below, click 'Print Head Alignment'.
  5. The following message is displayed. Click 'OK'. Print head cleaning starts. The power lamp flashes during cleaning operation. Do not perform other operations. After cleaning has finished, the first head alignment pattern will be printed.
  6. The following message is displayed. After printing has finished, click 'Yes'.
  7. Refer to the printed sheet, and select the pattern with the fewest visible vertical stripes in column A.
    <1> Example of highly visible vertical stripes in the pattern.
    <2> Example of the fewest visible vertical stripes in the pattern.
  8. Enter the selected pattern's number in the Column A box.
  9. Similarly, enter the selected numbers in the boxes for column B to F.
  10. After all numbers have been entered, click 'OK'.
Apr 09, 2008 | Office Equipment & Supplies
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 12, 2009 | HP DeskJet 3550 InkJet Printer
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Jun 01, 2009 | HP DeskJet 3550 InkJet Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Hp psc 1210 all in one
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Regards,
Lawrence
Jan 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP DeskJet 3325 InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
