Question about Kenmore 17459 Free-standing Dishwasher
Water in the bottom of dishwasher
Our dishwasher has about 2 inches of water still in the bottom of it after the drying cycle is complete. What do we do?
  • musavir Apr 28, 2009
    water not being pumped out at the end of the cycle !
  • max2002 May 23, 2009
    washing and drying but water still in thebottem of the dishwasher
    Problem Solver:
  • 18 Answers
Try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Posted on Feb 15, 2009
  • eleets1 Jun 02, 2014
    you can also run the dish washer empty and pour in one cup of white vinegar
Dish washer will not drain after the cycle is complete. There is about 2 inches of water remaining at the bottom of the dishwasher.
You may need to remove the drain hose from the bottom of your sink,put it in a bucket and try to drain your dishwasher.If this still does not work and you have a wet dry shop vac you can use it to drain the water from the hose this will also allow you to check for anything restricting the flow of water thourgh the hose.Once the water is gone you may need to remove the dishwasher from the cabinet and check the drain pump for something that is stoping the impellar wheel from turning.If there is nothing stopping the impellar thenyou will need to replace the drain pump.
I hope this hepls with your problems good luck.
Oct 08, 2011 | Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Water leaked all over the floor after completing drying cycle
It is probably a clogged drain line that dumps into either your disposal if you have one or directly in the drain under your sink you may have an air gap on the sink they tend to plug around this area.
Apr 27, 2017 | Kenmore 15121 Built-in Dishwasher
THERE IS A COUPLE INCHES OF WATER IN BOTTOM AFTER CLEAN AND DRY CYCLE IS COMPLETE
it sounds like your drain pipe is clogged up, clean the vent window out on bottom and it should be fine
Jul 24, 2009 | Electrolux Kenmore 24 in. Built-In...
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Draining problem
repace timer or water outlet solenoid
Jan 16, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Kenmore 17459 Free-standing Dishwasher Logo
904 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
