Question about HP Pavilion dv2715nr Notebook
Keyboard wont work.
I have an HP Pavilion dv2715nr Entertainment Notebook PC and all of a sudden, the keyboard seems to be locked. I tried restoring the computer. I did the sweeping thing with my spyware thing. just in case. and the mouse doesnt work either. the wireless mouse does. but i cannot type anythin on the computer. What can I do? I dont want to take it to BestBuy's Geek Squad cause they will keep my comp for weeks and erase my files. I need my comp for my school and i really dont know much about computers and technology so im very clueless of why and how is it that keyboard got locked? or if its broken? or why cant i type or move the mouse? please help me
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    did you try safe mode?
I had the same problem and called hp i was told to turn off my notebook and unplug the charger from the notebook take the battery off and hold down the power button for 30 seconds then reattach everything my keyboard started working again. i was told this happens because i donot let the battery die on my laptop or i keep it plugged in all the time which is true the notebook has to much static and the keyboard stops working. hope this helps
Posted on May 21, 2009
My keyboard of my hp laptop has stopped working completely. It all started by inputting wrong characters in word, with the num lock light sort stuck, i.e not going away no matter how many times I had to...
The keyboard should be replaced, I find it is a waste of time trying to repair something that is a throw away. I would suggest taking it to a computer tech for service and you may have use your restore disc again if you find the keyboard not working.
Dec 22, 2010 | HP Pavilion TX1000Z Notebook
How do I adjust the color, contrast and sharpness of my Dv2000 HP Pavilion?
You can use the "Fn" + F7 and F8 key from the key to increase the Colour and Brightness of the Screen
May 02, 2010 | HP Pavilion dv2715nr Notebook
Hp pavilion zt3000 keyboard locked and keyboard drivers will not load
turn on the laptop and try going into the BIOS, if you can get into the BIOS then you know the keyboard is only locked in windows. If you can't get into the BIOS cause the keyboard is not responding then the keyboard ribbon needs to be reseated and if that doesn't work then the keyboard is bad. If the keyboard is working, reboot again and keep pressing F8 and it should bring up a menu. Choose safe mode and you should be able to get in there. If you can then go ahead and go into the accessories folder in the start menu and into system tools and choose system restore. Choose the last date that the keyboard last worked properly.
Go ahead at this point and let the machine restore to that date and when it reboots it will bring you back into windows and at this point, the keyboard should work. If it doesn't then its a problem with the OS and you'll need to do a factory restore.
Jan 15, 2010 | HP Pavilion ZT3000 Notebook
My laptops keyboard wont work.its a hp pavilion entertainment pc.i had to write this through on screen keyboard
Sir, this problem one can face if the connection between the Keyboard and the computer is broken or to say disconnected. Try checking connection and also try to clean the connection. If all hardware points clear, the problem can be in the Keyboard Driver. It is either not responding of corrupted. Thank you, Have a nice day !
Sep 19, 2009 | HP Pavilion DV5234US Notebook Laptop
Caps lock an d scroll lock lights keep blinking
hello my friend, try to check the connector of your keyboard to check the status of your device. If its ok then try to used another keyboard maybe the device has a problem.
Jun 16, 2009 | HP Pavilion dv4t Entertainment PC - 2.4...
Computer won't stop scrolling up and scroll lock is off
heyy..don't panic... simple try to use USB(external) mouse & keyboard and for future use i wud recommend you to re-install your drivers or Operating system too...
Apr 23, 2009 | Acer Aspire 5570-2758 Notebook
Wont start up
- Try to run the System Restore.
Mar 14, 2009 | HP Pavilion dv2715nr Notebook
Hp pavilion entertainment pc no cursor at log in page; keyboard unresponsive.
First verify you keyboard works.
The easiest way to do this is to hit F1 when you see the HP logo.
This shouild take you into setup (bios)
If it lets you in hit F10 and exit BIOS.
Reboot.
Press F8 BEFORE windows starts to load.
Select safe mode.
Once in windows run a system restore.
To access System Restore, go to Start and select Programs, Accessories, System Tools, then System Restore.
Restore your system to a time when it was working correctly.
Mar 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP PAvilion DV 1000 Keyboard Problem
Seems like it actually may be a problem with the keyboard. Could be that those particular buttons are faulty. I would try a new keyboard. They seem to be cheap enough these days!!Hope this helps!
Oct 01, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion zv6000 Notebook PC keyboard replaced
Probably the keyboard you got is defective. I have seen buttons working in very bad conditions. When a key doesnt work or several is bad news.
Try to get a replacement. Since you have already reseated this simply check if the flex cable is properly locked, (ear plugs or similar) and not moving.
Mar 19, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion dv2715nr Notebook Logo
279 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
