Question about Whirlpool 25.3 Cu. Ft. Frost-Free Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Satina Stainless-Look
Whirlpool sidebyside FF stopped working after ? motor stopped ...
Whirlpool sbs Fridge Freezer had been running a little louder over some months, cutting in & out as usual (thermostat control), suddenly noticed this stopped over a couple of days, freezer stopped working but ice maker was working, fridge not working as well as it could. The jambs (black marviplate frame where the seals on doors abut) to the doors are very hot ...... this is what threw me. Could this be that the motor is shot? or compressor? or something less hopefully?
ps had to replace icemaker a few weeks ago with success
  • 1,075 Answers
This refrigertor is leaking refridgent gas it needs checked by an engineer
Posted on Feb 15, 2009
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Whirlpool ff 400 elite, probable pcb fault
compressor is running 10 menites after 10 to 15 minites compressor start
May 09, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Intermittent flapping noise whirlpool fridge freezer
Hi: Go easy on my rating as this is just something to try. You say it dosn't have a dispenser. Does it have an Ice maker? If so is it hooked up? If not try raising the lever on the ice maker up to the off position. The water valve may ve trying to open and without water pressure it will make a noise. It would also be related to the switches on the door. I hope this helps, Jeff
Jun 07, 2009 | Refrigerators
Whirlpool sbs fridge freezer - freezer stopped working
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Feb 24, 2009 | Freezers
Motor stopped running but lights & ice maker OK
this is most likely a bad condenser fan motor. pull refrig from wall remove compartment cover on rear and inspect the fan that cools the compressor. it is either jammed or seized up and needs replacing. while your at it you may want to clean the condenser coils as well they most likely have dust and lint build up on them. this motor is fairly easy to replace yourself if your mechanicaly inclined the part number should be 833697blade and can be purchased online, at a local appliance parts supply house, or thru a sears parts and servie center near you.
to keep the unit working until you get it repaired you can put a house fan blowing on the compressor area to keep it cool and this will get temps back to normal and cool down that center frame as well.
Thanks Peyton..
Feb 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Elite Model 795 77244601
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
Whirlpool 25.3 Cu. Ft. Frost-Free Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Satina Stainless-Look Logo
222 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
