Question about Sony KP-61V90 61" Rear Projection Television
MY TV WILL NOT STAY ON WHEN TURNED ON!
MY RCA 35" TV WILL NOT STAY ON WHEN TURNED ON. COMES ON AND GOES RIGHT BACK OFF!
  • Sony Master
  • 5,138 Answers
Pull the back off disconnect the CRT Board connected at the end of Picture Tube if TV comes on with sound then you have a Bad TUBE.
Posted on Feb 15, 2009
TV comes on n goes off,does 3 times
This is the Famous 3 strikes and out for RCA's--it tries to come on 3 times and if fails shutdown occurs.
The high pitched sound may be a short or could be something arcing--if the sound comes from near the very front of set--could be the HV splitter this set has arcing.
Apr 06, 2012 | RCA Televison & Video
RCA 35V432T 35" TV with crunched pcb (crt itc008 2127952A)
If the tub is not broke at the neck where the crt plugs on and the pins are all still there the there is a good chance that it will still work. You realey wont know untill you try and see. some shops might have a used crt board if they have had a tv come in struck by lighting and saved the board for what parts that was still good.I know i do that a lot. Dont think I got one for a 35 inch though.
Mar 05, 2009 | RCA 35V432T 35" TV
52" RCA Rear Projection TV. It doesn't turn on right way.
bad capacitors in the power supply is most likely.
could have bad ihvt and output transistor
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Tv won't stay on
Hello mrscarpenter,
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
Sony KP-61V90 61" Rear Projection Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
