Question about Gateway FPD 1830 18.1" Flat Panel LCD Monitor
If I Come Out Of Standby, Gateway FPD 1830 flickers, then black
I used to have a large monitor, but my dad was getting rid of his Gateway FPD 1830 since he was upgrading. So I took his. I am used to keeping my computer in standby, but when I try to do that with this monitor, it doesn't work well.
The monitor will flash on for a few seconds, then go to black. I have found that if I push the "Source/Set" button, the screen will come back for another few seconds. After doing this several times in a row, and opening up my internet in the second long glimpses I get of my screen, the monitor will stabilize and come completely on.
Once the screen's on, it's on. I have no further issues with it. So, yes, it's usable. But it is such a pain and takes minutes for me to load up my computer! And remember :) I'm used to coming out of standby lickety-split! I'm so irked with this monitor, I'm about to plug in my old, clunky, huge, curved monitor again--even though it is so much bigger than this flatscreen--just to save me time when I start up unless you all can figure out what the issue is?
When my dad used the monitor, he always had his computer boot up from being off, never used standby, and never had the problem. So I'm thinking, standby is the problem? Any way around this? Thanks!
  • 4 more comments
  • indyford88 Feb 15, 2009
    I'm not completely familiar with the Power Options. I went into Control Panel, clicked on Power Options, and under Power Schemes: Home/Office Desk my "Turn Off Monitor" is set at "Never". But when I go into standby via the Start Button to Turn Off Computer to Standby, the system goes into standby and my monitor goes to DSUB Power Save Mode (or something like that) and then goes black and the power button turns yellow. I don't click the power button on the monitor to turn it off. I let it stay yellow. When I wake the computer back up from standby, the monitor power button turns green, the screen comes on for a couple seconds, then black. But the power button stays GREEN. It does not go back to yellow.
    Once again, after a few minutes when I get the monitor to stay with me, it never goes out again, not even flashes or dims, until I put the computer into standby.
    So if that's what you meant by leaving the monitor on, then that doesn't work. If you meant something else, let me know. :) I don't know much about computers, so that's why I gave as much detail as I could so it might make sense to you.
  • indyford88 Feb 18, 2009
    I went to Power Options and told it to never turn off the monitor and to Stand By after a set number of minutes. It never went to Stand By.
    I've unplugged it and plugged back in my bulky, curved monitor. So weird to look at now, but at least it turns on. I gave the LCD monitor back to my dad. He has a friend at his wife's work that is going to look at it.
  • lafar Feb 19, 2009
    When I get here every morning my screen is black, while the other two identical monitors remain lit. I keep pushing the right hand button (source/set) and it flashes on for a second, then goes immediately black again. But while it flashes I must find one of the desktop icons and click on it; then the monitor comes on and stays on for the rest of the day. So frustrating.
    When I saw these messages I went outside and got my monitor back out of the dumpster! Help!
    Marshall LaFar
    Gastonia, NC
  • Jditty Apr 13, 2009
    I have the same problem. Doesn't seem to matter what setting I have it on, or how I power down & power up. I've tried every variation I can think of and adjusted every setting that I can. It just started all of a sudden.
    I have yet to figure it out....there must be something going bad with the unit.
  • Thomas F. Schneider May 11, 2010
    So, instead of turning it to stand by with the start button, just set the setting to standby after a certain amount of time of disuse and leave the monitor setting as it is. Worth a try?
    Under power Options you can leave the monitor on and " Stand By" the rest of the system. Might give that a try?
  • 328 Answers
It's a bad back light inverter. These models are NOTORIOUS for them. It's a simple fix for a technician and not very expensive. I fixed mine about 2 years ago and it's still going strong.
You can purchase replacement inverters and if you're handy with a screwdriver you can fix it yourself.
-=/ Daft Tech /=-
Posted on Oct 28, 2009
I have a Gateway FPD 1830 Monitor. I have to turn it on usually between 30 to 50 times to get it to turn on. What is wrong, and how can I fix it?
The power supply, the inverter, or the lighting tubes may be defective. I would bet that you need some new capacitors in the power supply or possibly some transistors. Those are the two main failure points that cause the quick power supply shutdown. It detects overload and tries to save itself from total destruction by shutting down.
I bet on capacitors, especially if you never turn the power off but let it sit in standby all the time.
Oct 27, 2014 | Gateway FPD1830 DVI/VGA 18-inch LCD Flat...
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
Complete power failure on gateway fpd 1830 monitor on last bootup. no light on power button and nothing on screen . A fuse maybe ?????
Could be the fuse. But typically it is the caps on the output have failed.
Usually can find repair kits on e-bay and repair if you are experienced.
Nov 04, 2013 | Gateway FPD 1830 18.1" Flat Panel LCD...
Monitor just stopped powering up one day. Is there a breaker or something?
There is main power fuse in the power supply module, but if the screen flashes on for seconds, then the problem is in the inverter board due to bad caps (very common in this model): http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD1830/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=fpd+1830+power+supply&um=1&ie=UTF-8&ei=y_-7S_uqDI628wTYvsDkBw&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CB0QrQQwAg
Hope my information will help you out.
Apr 07, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
Where can I buy on line the inverter board for FPD 1830
eBay is probably the best and easiest source for this item.
Dec 28, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
COMPUTER SCREEN WILL NOT EXIT POWER SAVING MODE BY HITTING THE BUTTON,SCREEN IS BLACK
boot up the computer with a disk in the drive and uninstall the driver and reinstall it
Jun 06, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
Gateway FPD1830 Monitor Flickers then goes black
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 03, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Monitor works on and off
After usual overheating the capacitors, the weakest spot in FPD1830 are four chip resistors located in the inverter board a bit above the middle, you can recognize them as they are bigger than others and located all four in one row. Holding by tweezers simply re-solder them to get rid of micro-cracks in the tin between pads and resistor contacts.
Aug 12, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Gateway FPD 1830 18.1" Flat Panel LCD Monitor Logo
705 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
