Question about Samsung LTN468W 46 in. LCD Television
Daughter sprayed water on samsung lcd 32 inch on the front panel
At first colour on screen went all pastel colours flickereed back and fore to original colours now I have a blank white screen and on the left about 8 inches vertical thin stripey lines we dried the tv very quickly she had only sprayed water on the bottom part of panel only had tv 6 weeks and didnt take extra warranty out!
    Genius:
  • 1,075 Answers
Electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
Posted on Feb 15, 2009
I have a Haier Hl32d1 32 in. TV. When I watch for a while the colour gets all messed up and become bright pastel colours like a lava lamp.
Hi Jesse, This is interesting. Please open the menu in "Lava like state"If the menu comes ok it is the main board causing this problem and if the menu does not appear properly, it may be due to bad display unit. Please consult some qualified technician.
Jan 08, 2014 | Haier HL32D1 32 in. TV
Screen colours
The T'Con board should be suspected. Contact any experienced service technician. This symptom can also occur if the display panel is faulty. Check this link.
Sep 27, 2012 | Samsung LE32B450 32 in. LCD TV
Flashing red,blue, green screen
last week i had an emerson 21 inch with built in dvd.,it was flashing colours.none of the front buttons would work.i unplugged the front buttons and plugged them back in again.set is working fine.ican not remember if i did it with the power on or off.try both.some how the front buttons were locking up the micro.
Nov 24, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My daughter threw a toy at the tv. The TV is not cracked but the is a splash colour on the screen. can it be fixed/
Hi, Unfortunately this is a crack internally, the spalsh of colour is the Liquid Crystals running through the cracks, the cracks can be very fine and not visible because of the spread of liquid. this can't be fixed, it would require a new screen which could be very expensive if you can get one.
you could try claiming on household insurance if it covers for things like this.
Hope this helps.
Feb 13, 2011 | Samsung LN32A330 32 in. LCD TV
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
My daughter dropped my 32 inch flat on the screen and now the colour is funny
the description is useless. funny how ? off? cracked screen? blue, red, what? need some information to help you please.
frankly after a drop I would say the tv is damaged beyond repair
Jan 31, 2010 | Televison & Video
Samsung tv prob
My daughter's LCD which is barely used started showing horizontal coloured lines.I read that the LCD's are vunerable to static/charge build up and also power surges.
I unplugged my daughter's TV and it is now working properly however we now unplug the TV when it's not in use.
I was considering purchasing a larger model for the faily room but Not going to waste my money until they improve this rechnology.
Good luck to all.
Cheers!
Mar 22, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Discoloration from water
I dont think your daughter did any damage bacause the water can not get into the set form the front unless the water went in thru the holes in the back,in that case water can cause a lot problems,it will dry but it will also damage some components,if the water went in from the back you need to take it somewhere to get it clean so it does not built up corrosion with time.Good luck.
Sep 19, 2006 | Samsung LTN468W 46 in. LCD Television
Weird colors problem
i have a samsung LCD tv 32 inch tv. when switched on the pic is seen for about one sec then goes off. when i change channels the audio changes but the screen is blank. every time i switch off and on the same thing is repeated there is no display on the screen looks like a back screen light fail . can the problem be sorted out by changing the inverter or the whole LCD panel needs to be changed? pl be free to answer.
Aug 17, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LTN468W 46 in. LCD Television Logo
386 people viewed this question
Henry  Thomas
Henry Thomas
