Question about LG Shine KE970 Cellular Phone
Powering On I left my LG Shine powered off for two weeks with the battery in it and now it simply will not power on. I tried plugging it in using a USB cable to the computer and it just says AT&T and flashes every ten seconds. Any Solutions??
    New Friend:
  • 12 Answers
Try taking the battery out and carefully cleaning the connections, preferably without liquid but if necessary using a liquid that will evaporate i.e. methylated spirits. A small amount of corrosion may have occurred over the two weeks that could be causing battery problems.
Posted on Feb 15, 2009
Battery on lg shine not charging and not showing how much battery life is left
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 02, 2012 | LG Shine KE970 Cellular Phone
Battery power not working
Try Removing your battery first then unplug the Power adaptor from the system, then press and hold down the power button to do a power drain on your systems motherboard.
return your battery then try powering the system using battery only.
if the system still wont power up using battery, plug in your adaptor go in windows, go to add remove programs or programs and features depending on what windows your system has, once in either one of the two look for energy management uninstall it from your system then restart the computer one last time try powering using your battery only.
If still this does not work powering the system using battery try updating drivers for your motherboard go to the lenovo website consumersupport.lenovo.com for the chipset drivers download
if still nothing has changed call lenovo probably something is wrong with your motherboard or battery you may need to send the system back to lenovo for further checking.
Jul 06, 2010 | Lenovo 3000 C200 Notebook
Won't turn on
Try taking the battery out and powering it up.
Dec 17, 2009 | Toshiba Satellite M305D Notebook
I have the lg cu720 shine
turn the phone on remove the battery cover and remove the battery while the device is still powered on then proceed to remove the sim card and clean the contact surface well with a dust free cloth replace sim card battery and cover. if problem persists contact customer care
Aug 03, 2009 | LG Shine CU720 Cellular Phone
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
LG VX 8600 - My phone was dropped and now when powering on - it won't go passed the "Verizon Wireless" startup screen. I'm eligible for an upgrade through verizon, but is there anyway I can get my...
Try plugging your phone in to a power supply so that it's running off a different power source, then power up your phone. You should then be able to copy off your contacts. This worked for mine which I'd left outside in the front lawn through the WHOLE WINTER and just found it after the snow melted. Sure enough it works, however I need to have it plugged in to a charger to actually use it. Give it a try, worked for me.
Mar 19, 2008 | LG Chocolate Clamshell VX8600 Cellular...
ITunes
No, I don't think so. I have tried.
Dec 11, 2007 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
55 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
