Question about Refrigerators
Ice building in freezer and water leaking in the fridge section
The fridge model is an E521T  active smart  6-7 years old
I recently get Ice building up in the freezer   I have turned it off for a couple of days to dry it out
it has happened again but this time water leaks out of  the refrigerator  section from what i can see is the  ceiling part under the freezer compartment
Is there something I need to check or do i need to call someone in
  • 359 Answers
I will say that you may have to call someone in, but it is most likely the thermostat for the freezer, when the freezer reaches setpoint, that stat will kick the compressor off, but it sounds like yours is running until it the coils freeze, which brings another problem in hand is a dirty coil. Those two are your best bet. Best of luck!!
Posted on Feb 15, 2009
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Fisher & Paykel E521T Fridge Ice Build up behind Freezer compartment. I have had my fridge for about 7 years and ever since I bought this fridge I have to defrost it every 6-8 months because water...
Have they cleaned the drain tube that runs down the back of the fridge? If not and the tube is clogged water will back up and give you the problem that you are having. The only other thing that I can think of, is that the defrost cycle may not be set to a minimum amount of time to where this can be increased to allow the freezer not to let the ice build up.
Apr 19, 2017 | Fisher and Paykel Active Smart E522B...
Water is dripping down the back wall of my hotpoint refrigerator model # CTX21DA. The water collect at the bottom and drips onto the floor. How old is the refrigerator and what would the cause be for...
The problem is relatively simple to repair. The drain tube in the freezer is blocked so the water will drain down the back of your fridge. Often the drain gets blocked by ice build up. The defrost circuit in your fridge has failed and ice is building up on the evap coil in the freezer. When the ice builds up, it blocks the drain tube. The typical failures of the defrost is the timer failing to advance or the heater is burned out. Being that said it was probally manufactured at least10 years ago, and certainly a new refridgerator would be more energy efficient and cheaper to operate than using a 10 year old model. Whether you should repair or replace it depends on whether you have the money to replace it. Hope this helps you.
Dec 06, 2010 | Hotpoint Refrigerators
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Fisher and paykel e521t icing issue
should be a hose going down to drain pan, check it, could be plugged, or compressor on way out an controll not workin prop.
Jan 04, 2010 | Freezers
My frost free fridge freezer is crating ice at the bottom of the freezer section.Its about 8 years old
drain is blocked. take back panel off inside freezer and there is probably ice build up in the drain tray. melt off with a hairdryer and follow up with hot water till drain flows freely
Aug 09, 2008 | Bosch Refrigerators
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
575 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
