Question about Kenwood KDC-122 CD Player
We just bought a new cd and it's stuck in the car stereo
It's a KDC-122. It won't eject. You can hear it try to when you press the eject button. Pushing the select button won't bring up the CD player. It only goes to tuner and off.
Mine does this to its just that the disc goes in to low so i took an old cd and stuck it under the one inside and it ejects out but this is able to scratch your good cd
Posted on Nov 07, 2009
    Scholar:
  • 24 Answers
If you like you can read throuh the manual for further help if this fails,
at this address :
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf
However the units have a forcible eject mode, im raking my brain for it but i think 90%  sure its as follows...
Try pressing and holding eject and the power button at the same time for about three to five seconds, the machine shoudl buzz louder then normal an do a full eject cycle for about 2 seconds,
If worse comes to worse you can take off the outer casing  four screws (if not under warranty) and carefully lift the disc slightly and slide it out. Take care to to force anything as you can damage/scratch the unit.
Another option is that you ring the Kenwwod customer service number and ask how them what the button press combination is for forcibly ejecting cds from the unit. you may need to ask for someone in repairs there to get a knowlegable answer,
Hope this helps
Cheers
STeve
Posted on Apr 03, 2009
Cannot load cd into slot
silly question but is a cd in there? try pressing the eject button if not anyways to see if the player thinks there is one in there. if not try shutting power off then turning back on
Nov 22, 2013 | Kenwood Kdc-Dab4551U CD Mp3 Car Stereo USB...
Cd jammed won,t eject
Hi.
Try pressing repeatedly the eject button on the on dash player while turning on the stereo at the same time. If that does not work disconnect battery terminal for one minute to reset the electrics and try again pressing eject repeatedly on startup. Make sure that you have the stereo anti theft code if needed before disconnecting the battery.
If that does not work, then the unit must be disassembled. The car stereo must be removed from the dash. The unit must be disassembled removing screws at back and bottom and undoing metal casing clips. That will reveal the CD drive allowing to remove the disk.
Regards.
Ginko
Sep 14, 2011 | 2006 Pontiac G6
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I HAVE A KENWOOD KDC 122 CD CAR STEREO. THERES A CLOCK ADJUSTMENT BUTTON,WHEN I PRESS THE CLOCK ADJUSTMENT BUTTON THE CLOCK "FLASHES" BUT I DON"T KNOW HOW TO SET IT,I DON"T KNOW HOW TO MOVE THE NUMBERS,IF...
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Mar 09, 2009 | Kenwood KDC-122 CD Player
Pioneer Premier DHH-P930 cd stuck, how to eject?
The eject button is on the lower right hand corner. The button should say open. It opens the face plate
Jan 31, 2009 | Pioneer DEH-P930 CD Player
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Cd player wont eject
You can try pressing the reset button on the display, it is a very small indented button that you need a paperclip or something smaill like that to press it. This is the only user action that can be done.
Do you hear the cd mech making any noise at all (gears trying to turn, motor running)? if not, you may have a supply voltage out for the cd mech, bad ribbon cable, defective loading motor, or one of several other possibilities.
If you hear something trying to happen, it will most likely be a jammed up mech. There is a plastic piece inside the mech that is very difficult to get to that may need to be replaced or at least re-aligned.
If you are not familiar with these type of mechs, you really should not try and fix it, you will most times cause more damage to it.
sorry there was not better news for you. let me know if resettng helps or if you feel you can fix it yourself, I would be glad to offer more help.
Jun 12, 2008 | Kenwood KDC-516S CD Player
Kenwood KDC-122 CD Player Logo
183 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
