Televison & Video Logo
Brandi hicks Posted on Feb 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just got this remote and my tv is not in the codes and it will not program to my cable box ;( help pls
Look like an iPhone my tv code is not in the book my tv is an element and will not code up with my cable box ;(
Level 3:
Top Expert:
  • Universal Re... Master 76,851 Answers
  • Posted on Feb 20, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994572
Points
237762
Do a code search. If there is any code in the pre-programmed list of remote control, you can win. Refer its user manual for details.
5 Related Answers
Anonymous
  • Posted on Apr 08, 2009
SOURCE: i have a URC-R6 universal remote and i don't have
http://www.universalremote.com/resources/pdfs/avex_manual.pdf
Anonymous
  • 8 Answers
  • Posted on May 25, 2008
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Anonymous
  • 594 Answers
  • Posted on Jan 08, 2009
SOURCE: codes for my sanyo tv
please give me them the model number of your remote and i would be glad to give you the codes
Anonymous
  • 77 Answers
  • Posted on Jul 18, 2009
SOURCE: need codes for Sentry RMC10 Really Big Universal Remote
For your reference, the manual is here:
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
otherwise go the home site
Anonymous
  • 7 Answers
  • Posted on Aug 31, 2009
SOURCE: codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
I have a Trutech PLV1615T TV and a RCA RCR311 Universal Remote that I lost the info for. How can I get them to talk to each other....Thanks, Tom
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: y TV-000 y VCR-000 y Cable Box-000 y AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
3helpful
2answers
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
  • TV-000
  • VCR-000
  • Cable Box-000
1helpful
Need to program a new remote for RCA TV
  • TV-000
  • VCR-000
  • Cable Box-000
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
2answers
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
7helpful
5answers
7helpful
3answers
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
