Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Logo
A
Anonymous Posted on Feb 19, 2013
Orange blinking light
On the front top of the machine there are two lights. The one on the top is flashing orange. What does this mean?
1helpful
What do the green and orange lights mean when they are shown on a Rancilio coffee machine. Is the orange an indicator that the water is heating?
On Rancilio coffee machines, the meaning of the green and orange lights can vary depending on the specific model and configuration of the machine. However, in many Rancilio espresso machines, the lights are used to indicate certain states of the machine during operation. Here are some common interpretations for the green and orange lights:
  1. Green Light: The green light on a Rancilio coffee machine typically indicates that the machine is powered on and ready for operation. When you turn on the machine, the green light should illuminate to show that it has power.
  2. Orange Light: The orange light often indicates that the machine is in the process of heating water to the optimal brewing temperature. Once the water reaches the correct temperature, the orange light may turn off, and the machine is ready for brewing.
  3. Blinking Orange Light: A blinking or flashing orange light might signify that the machine is in a heating phase, and the water is being heated to reach the appropriate temperature. This is common during the initial warm-up or after the machine has been idle for a while.
  4. Red Light: Some Rancilio machines might use a red light to indicate specific alerts or warnings, such as low water level, need for maintenance, or other issues
2answers
Nespresso machine discaled and orange light still flushing
must enter descaling mode to apply it properly then it will work
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
1helpful
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
2answers
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
2answers
9helpful
2answers
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
1helpful
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
2answers
Lower light blinks on everytime I try to print anything and nothing prints
Check for any paper jams, I think the orange light mean that there is a error and therefore cant print, check incartriges and other areas inside
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
