Question about Acer Aspire 3610 Notebook
Water spill My highly intelligent (Ha ha) stepdaughter knocked a glass of water on her laptop the other day (just informing us that it wont work now,) Is there anything we can do or perhaps or this covered under the warranty? She has only had it since Christmas. The "on" light still comes on but no screen (guess the light is water resistant huh?
    Genius:
  • Acer Master
  • 1,102 Answers
Should still have warranty but not all warranties cover this.
do not try and take it apart to dry yourself or all warranty for the laptop will be void.
i recommend you return it and let them fix it
even you have to pay due to the fact that even if it does dry out and become workable again you will have corrosion.
i also recommend no food or drink by the laptop to prevent accidents.
Let me know if this helped
please rate me
thanx
Posted on Feb 15, 2009
Cooling System Failure 2000 Chevy Cavalier 2.2LOHV
Did you have the head checked, they have been known to break inside the runners . I always used a vacuum fill system when working on these, jack up the pass front corner when doing a coolant refill, that should eliminate an air lock
Nov 05, 2017 | 2000 Chevrolet Cavalier
Karcher 620m pressure washer wont start up or pump water. power light on at on/off button. havent used it for at least 2 yrs.guess something ceased ?? also cant find how to get the casing of to have a...
Its the spill valve that stuck under the micro swith, this is quite easy to fix, to take the cover off there are 3 square plastic tabs under the machine, pull these out about 1/2 in that releases the tabs on the case's edge press the case inwards where the tabs were & take cover off, at the hose end the black cover is held by 4 torx screws, take that off and remove the detergent holder, then take the 2 torx screws that hold the micro switch out, pull that away forwards & sideways, take the 4 torx screws off the cylinder head cover & take
the spill valve out, this is probably stuck so take care not to damage it as you try to pull it out, clean the valve & most important clear the bore in the cylinder head, its probably built up a white powderlike aluminium oxide, be careful not to scratch the bore, lubricate the spill-valve & it should now push back with not much resistance, now put it all back together, you could test to see if its workind OK before you fit the top cover, (if it doesn't you haven't cleaned the spill-valve & bore properly)
NOW DO IT AGAIN PROPERLY HA HA HA
Feb 17, 2011 | Karcher Electric Cold Water Pressure...
2 stroke mower has fuel and spark but will not start
Sometimes water (condensation) can get in the gas. If your model has a bowl on the bottom of the carburator, loosen the bolt and ease the bowl down and take it off. You will spill gas out of the bowl but that's ok. look at the spilled gas while you're at it and see if you see beads of water... tell-tale sign of this as being the problem. I'd get a paper towel and dry the bowl out before reassembling. To make sure there's no water in the gas tank, you could loosen the fuel line, drain the gas into a container (preferably glass so you can see if there's water in the bottom of the container, afterwards). If there was water, you might swab the bottom inside of the tank out with a paper towel. Reassemble everything and put in some fresh gas. You might can re-use the old gas, just don't pour the water back in... ha.
I hope this helps... Good luck!
Aug 31, 2009 | Garden
Craftsman 917 6.7 power start will not run for more than 2 minute, it keeps shutting off. New spark plug, filter installed. Oil looks good.
Sometimes water (condensation) can get in the gas. If your model has a bowl on the bottom of the carburator, loosen the bolt and ease the bowl down and take it off. You will spill gas out of the bowl but that's ok. look at the spilled gas while you're at it and see if you see beads of water... tell-tale sign of this as being the problem. I'd get a paper towel and dry the bowl out before reassembling. To make sure there's no water in the gas tank, you could loosen the fuel line, drain the gas into a container (preferably glass so you can see if there's water in the bottom of the container, afterwards). If there was water, you might swab the bottom inside of the tank out with a paper towel. I'd check the filter for trapped water as well. Reassemble everything and put in some fresh gas. You might can re-use the old gas, just don't pour the water back in... ha.
Aug 25, 2009 | Garden
My Poulan runs for about 5 minutes then dies and won't start again for about 20 minutes. Then the same thing. Any advice?
Aug 23, 2009 | Poulan Pro 22" Self Propelled High Wheel...
I have a DYT 4000 riding lawnmower that will start and ramp up and die
Sometimes water (condensation) can get in the gas. If your model has a bowl on the bottom of the carburator, loosen the bolt and ease the bowl down and take it off. You will spill gas out of the bowl but that's ok. look at the spilled gas while you're at it and see if you see beads of water... tell-tale sign of this as being the problem. I'd get a paper towel and dry the bowl out before reassembling. To make sure there's no water in the gas tank, you could loosen the fuel line, drain the gas into a container (preferably glass so you can see if there's water in the bottom of the container, afterwards). If there was water, you might want to let the empty tank dry out. Reassemble everything and put in some fresh gas. You might can re-use the old gas, just don't pour the water back in... ha.
Aug 23, 2009 | Craftsman Garden
One day when i was playing my xbox360 the power went out and it shut off when i was playing it i was using my wireless controller and it would not work it just kept on blinking........i dont know what...
YOUR STUPID *** PROBALLY PLAYED IT DEATH STUPID *** HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA LOLOLOLOLOLOLOLOOLOLOLOLOLOLOLOLOLOLOO, YOU HAVE TO ADMIT THAT WAS KINDA FUNNYHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHA
Apr 19, 2009 | Microsoft Xbox 360 Controller
Acer Aspire 3610 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
