Question about JVC AV-27430 27" TV
JVC AV27430 picture seems to have lost the red color
The picture is very dark and seems like there are no reds and I tried to adjust the focus and brightness at the back of the set and with the remote
  • 129 Answers
Hi, good day.
Pls check for loose contacts along the crt circuit and likewise, the possibility of a defective crt socket
mycho
Posted on Feb 15, 2009
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
JVC 56TH INC. IArt Rear Projection
If the red is colored outlines or 3d picture then it is a convergence problem.
If convergence is ok, then most likely screen/focus control assembly.
Easyab
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Picture has gotten darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Mar 23, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-27430 27" TV Logo
208 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
