Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire dishwasher wont run
My dishwasher wont start. The only thing it does is shine it's little green light by an icon that looks like a lock
Thanks for your help. My dishwasher did the same thing today -- green lock light came on and I couldn't get it to run. I checked the bottom of the tank and I had some glass lodged in the drain. Cleaned it out and held the button down for 5 seconds and now it runs again.
Posted on Feb 28, 2009
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Posted on Feb 15, 2009
I had this problem also. Try holding down the button that the "lock" is near for a few seconds. I believe that the lock turns on when there is a large object obstructing the water flow or propellor. When I cleared the pathway (a glass broke and there was a shard still on the bottom) and held down the button, it turned off and I was able to start another cycle.
Posted on Feb 27, 2009
Frigidaire dishwasher FDB1050RE
Dishwaher will not start. Wash light blinks.
Checked for obstructions, etc.
Posted on Mar 06, 2009
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
The light on the pad lock icon is on and i can't do anything with the dishwasher
The lock feature is there to keep little fingers from turning on the dishwasher. Usually if you push and hold the lock button for 3 seconds the light will go out and the feature will deactivate.
Mar 16, 2010 | Frigidaire Dishwashers
Light is on the lock icon. Can't get it off
Press and HOLD the lock button down. It toggles the lock feature when you hold the button down. The lock light went off and the unit works again.
Dec 19, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire gallery series dishwasher wont start
the only other thing i know to tell you,without knowing more about this problem,is check the float switch in the tub(its under a tall cover,remove this cover & make sure it is'nt stuck in the up position)otherwise it could be anything from the water inlet solinoid,a bad switch,or even the pc board.hope this helps
Nov 15, 2008 | Frigidaire Dishwashers
Will not run unknown light on
PRESS AND HOLD THE KEY WITH THE LOCK UNTIL THE LOCK LIGHT GOES OUT.
Apr 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Brand New Frigidaire slid in stove
look closely at the control buttons one should also have that same icon on it somewhere, youll need to hold it in for 3-5 secs to unlock the controls. its a child safety feature so the kids wont accidentally turn it on
Mar 16, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
987 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
