Question about Toshiba Satellite A15-S127 Notebook
Blank screen how 2 get the screen back
  • wonder16 Mar 13, 2009
    my toshiba, satellite, A15-s127, turns on then the screen goes black
  • 544 Answers
updated bios to the latest version - thats solution number 1, solution 2 - setting procesor to work 100 % all the time - thats a solution from toshiba service but i dont think it is a solution cause it is not a portable laptop anymore, it also doesnt work a lot, solution 3 - removing toshiba power saver from registry - dont know where exactly is toshiba power saver program in registry now but try to google, or just uninstall it, solution 4 - overheating - install for example Notebook hardware control and check the temperature of your cpu or maybe some tool or software that can monitor your graphic temeperature would be good, solution 5 - install all avaible updates of vista, solution 6 - send it to repair service if you are sure that you tried everything - maybe it is a problem with motherboard or graphic...
Posted on Feb 16, 2009
Monitor displays for about 2 seconds then screen goes blank. switching monitor of and back does same 2 seconds the blank screen. tried on 2 different computers , problem still persists any clues thanks
The problem can be caused by bad caps (bulging or leaking) in the power supply, bad inverter back light circuits, or worst case will be lamps. Look for bad caps first since it is easy to see, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Most monitors will fail after 2 years.
Feb 22, 2010 | Belinea (101705) (Gray) 17" LCD Monitor
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 | Cell Phones
Screen goes blank 2 seconds after powering up and then wont work
contact your service provider for a repacement phone if you have warranty or phone insurance. its and internal problem.
Apr 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Nokia 6126 screen not showing
the problem is in display...better change ur display and use it...
Sep 19, 2008 | Nokia 6126 Cellular Phone
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Cannot send or receive pics
Here are the MMS settings you will need to setup and/or verify:
From the standby screen, press the Menu Key.
Scroll to "Settings," press Select.
Scroll to "WebAccess," press Select.
Scroll to "Web Sessions," press Select.
Scroll to "Cingular MMS" press Menu.
Scroll to "Edit," press Select.
Validate the following parameters:
Homepage: http://mmsc.cingular.com
Service Type 1: HTTP
Gateway IP: 66.209.11.32
Port 1: 9201
Domain 1: leave blank
Service Type 2: WAP
Gateway IP 2: 0.0.0.0
Port 2: 0
Domain 2: leave blank
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
CSD no 1: leave blank
Username: 1: leave blank
Password 1: leave blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: leave blank
User Name 2: leave blank
Password 2 leave blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Scroll to "Messaging," press Select.
Press the Menu key.
Scroll to "Inbox Setup," press Select.
Scroll to "MMS Message Setup," press Change.
Scroll to "Server Info," press Change.
Scroll to "MMS", press Menu key.
Scroll to and select "Edit".
Validate the following settings:
Service Name: MMS
Server Name: http://mmsc.cingular.com
Web Session Name: MMS
Dec 17, 2007 | Motorola Mobility RAZR V3
Cant pxt or recieve tone downloads (parallel import phone)
Please verify that your settings are as follows, and then you should be all set!
(if not there select "new")
Port 1: 9201
Service Type 2: WAP
Port 2: 0
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
Speed (Bps) 9600
Line Type 1: ISDN
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Press the Menu key.
Service Name: MMS
Dec 14, 2007 | Motorola Mobility RAZR V3
Toshiba Satellite A15-S127 Notebook Logo
191 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
